  • Replies 120
Posted Images
hey everyone sorry I went away for easter Ill get onto everything tomorrow for you all.. Pretty sure i got some rear seat belts left =D I could have that plug I'll take a pic and see if what Im thinking is what you want!! I have intercooler and side piping =]
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
