I have Alcon front kit with 343 mm rotors, but thinking about these kits http://www.jdl-brakes.com/special-offer-alcon-adv-extreme-brake-kit-front-and-rear-nissan-skyline-r32-r33-r34-gtr.html What wheel do I need to clear 6 pistons calipers with 365 mm rotors ? 18x9 +15 would be ok ?
What wheels specifically? A R34 GTR rim won't really work as any small stone that gets caught between the caliper and wheel will get caught for example.
At JDL website, you can download caliper profile, and check clearance with your wheels : http://www.jdl-brakes.com/alcon-adv-extreme-brake-kit-front-6-pot-o365x32-nissan-skyline-r32-r33-r34-gtr.html
From my experience 9x18 ET15 will work ok with Alcon 6 piston caliper.
Will depend on the type of rim, I used the template and it did not clear my 18x10 +15 work meisters deep dish
Which model of work meisters do you have ?
My brother-in-law, has 18x9.5 +23 meisters on his R33GTR, and there is still 4-5 mm of clearance. Did you use template properly ?
Did you mean 6 pot Alcon kit as here : http://www.jdl-brakes.com/alcon-adv-extreme-brake-kit-front-6-pot-o365x32-nissan-skyline-r32-r33-r34-gtr.html
It would all depend on the disk faces of the rim:
R disk for: big caliper clearance.
A disk for: meh calipers.
O disk for: who cares about stopping, take the calipers off and get as much diiiiiish as you can.
mine are O disk, due to dish it tapers back on the back of the rim which fouls the calipers
Is the ATTKD brake kit from just jap the same product as D2's?
Also, UAS has a few interesting big brake kits under $3k
http://nismo.com.au/pricelists/pricelist_gtrbrakes.htm
Are they worthwhile upgrades? Namely the AP Racing upgrade
Which one is the 3k? Most prices appear to be either front or rear kits only not a set, may as well jump on the D2 groupbuy
Cheers thanks for the feedback
Will these fit under a lmgt4 18 x 9.5 +12? and yeah ive seen the template but im a lazy bastard lol
6CF28A3A-64B1-4D3B-85ED-AC1446AD8C5F-147
Yep. Here they are on mine (Using GTR JOEY's LM's at 18 x 9.5 + 12). They don't really fit under a R34 GTR wheel. Yes the wheel will go on, but there is so little room that little stones get caught between the caliper and the wheel.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
