id be buying the parts secondhand, aim is mostly some extra bottem end torque, used as a daily, would like a similar setup to say a VL turbo where theres no intercoolers or fancy manifolds..
Does the following sound realistic: assuming 6 or 7psi like a VL turbo would run
secondhand Gt3082/gt3076/gt3540 for $1000
walbro pump $160
possibly fabricate own manifold and short dump 3inch $ 800
some kind of chip/remap of computer $1000 using a fuel reg and stock injectors
bought car as a repairable write off for $1200, just needs some work with the front where the bumper fits, apart from that its very nice and is dual fuel and looked after so would be an nice project for a torquey daily driver..
thoughts anyone?
Edited by SliverS2
plenty of people have done turboed falcons (from ea through to au). 200kw is a very reasonable goal too. i wouldn't be suprised if it was higher though.
the biggest costs will be the ecu, tuning, turbo, piping (exhaust and cooler piping), cooler and setting up oil and water feeds to the turbo. and if you don't have a lsd, you might want to think of sorting that out too. the sort of torque that a 4L NA+T puts out will result in lots of wheelspin from an open diff.
Probably cheaper to sell it and get a ba xr6t...
ive heard alot of reliability issues with ba models and extra weight, and also an au would be unique so with the very small cost so far, a turbo conversion would be interesting, not for drag racing but just smooth torque for daily low revs stuff, be nice to hear a 3076 at work under there... have seen stock ba xr6 injectors, manifolds and dump for very cheap, makes it an attractive prospect, manifold would need some modifying though,
Geetee- thanks mate, id take that turbo, but just at planning/considering stage..
Edited by SliverS2
fordmods.com
A bit of info there.
thanks, some good info there
most falcons seem to gt3582's upward, i wonder if a gt3076 with a .82 or 1.06 would work well, as id like the turbo to be able to start pulling pretty much straight off the line with the auto like a VL would ,
also from what ive read the stock computer uses a map sensor so it may run safely on low boost, but a chip probably a good idea
Im not a fan of supercharging, i like hear turbo spooling noises and the sudden surge of torque comming onto boost compared to the linear delivery of the supercharger..
Edited by SliverS2
Ive git one in my driveway, remember xr6's have the tickford motor which is higher comp, This one is auto with a built box(the stocker didnt last long) running a 1.06 twin scroll gt35r, i think a 3076 would be fine as long as you ran a 1.06 housing. What are your plans for the dual fuel that would be the biggest issue, but you could put gas injection on it whaich runs its own ecu, just be limited with HP, dont want to end up spending 10K to get the whole thing done
well its a sprint gas system so i dont know how it works, wether it part of the petrol computer of seperate, i know it runs petrol first then after it warms up a bit it switches to gas if selected for gas ,( has a switch for gas/fuel), might need a computer that can handle two maps and have it tuned with two maps?
i really want to make it a low budget setup, $3500 max.. all second hand parts and do fab work myself if i can.. gas injection isnt really an option, i wonder if it could run the turbo on say upto 5psi and then switch for upto 8-10psi, or maybe the gas map would have reduced timing.. certainly throws a spanner in the works
how does the tickford respond the the gt35? is it laggy at all
Edited by SliverS2
you can get kits from snort performance for a reasonable price and they come with pretty well everything.
http://www.snortperformance.com/index.php?option=com_content&view=category&layout=blog&id=9&Itemid=9
No need for expensive manifolds.
Just buy a flange and have it properly welded to the original manifold and make the exhaust to suit. Fab up a bracket to support the turbos weight.
Grab the oil feed from the pressure switch port.
Drain back to the sump obviously. (Sumps not hard to remove of the old XR6's)
Water lines from the heater hoses
Run it with a factory BA cooler and make up some piping to suit.
Not long ago I did a bolt on turbo conversion to a dedicated LPG FG falcon. It made as much power on LPG as any other stock XR6T I've seen. If did require upgraded gas injectors and three LPG pump units with an aftermarket control unit.
Do your research about performace LPG systems, there is massive amounts of performance parts and injectors etc out there.
None of its cheap but the results are interesting
Thanks, ive been browsing ebay and gumtree etc, seems the stock xr6 turbo gear is fairly cheap so shouldnt be too hard to make it a reality,
Im still wondering what turbo should be used, my options as i see it for a budget build are the following
Kando dynamics T67
Second hand garrett
Precision
To make it cheap as possible would need the stock dump to bolt straight up so i think that rules out the kando, and from what ive seen the precision turbos have a 5 bolt housing but looks like its only 0.63, the secondhand gt35's are bit of a gamble though
Any opinions/advice on what turbo selection? im thinking now it has to be a gt3540 spec , a kando with a 5bolt ford rear end would be ideal but dont think that exists?
Edited by AngryRBGTX
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
