Chucked some wheels on I had laying around till my 19's rock up from japan
Tures arent the right size for a 35 but just what I had.
Fronts Work VS-KF 18x9+9 (15mm spacer so -4 effective) and Work euroline XR 18x9.5+8 with some 275/35 I had no use for
I haven't done anything to my car recently apart from gearbox/clutch/flywheel which was fun....
next on my list new rotors and pads, then to save my pennies for some Motordyne goodies.
I finally got my Tomei headers on, no issues with the steering column :)
Gained 6kws haha Nothing crazy dyno wise but can definitely feel/hear the difference :) (Now I have Tomei headers > Berk HFC's > TDX2)
Got the headers and retune done at ECC (East Coast Customs), great guys!
Also off topic, whilst I was there a supercharged 350Z made 284kws on the dyno, the charger sounded crazy loud
double like.
nothing big but I fitted a grounding kit on my car last night...improved transmission straight away. so much smoother and lag reduced greatly. really happy with the kit!
Edited by colin.ssc
Gratuitous rim shot...
Picked up the rims Thursday, Pirelli P Zeros on Friday lunch, rims on Friday night.
BC coils and SPL arms in next.
But not before i finish this damn stereo. Have been driving for a month in total silence. Got the sub in last night.....but nothing connected to amp yet.
Edited by SMOKEYV35
How good is the VQ with headers. Got mine done through them also. Got a vid up?
Why would there be issues with the steering column?
Tomei are Japanese and Japanese cars are RHD in case you hadn't noticed :P
Haven't really had chance to drive the car much only had a miserable rainy drive on the highway back home. Unsure if there will be a video, the video doesn't really do the exhaust note any justice
Here's my first dyno run a few weeks back when I didn't have extractors (Berk HFC, TDX2):
I checked with Tomei USA if the headers they sold in the USA were the same as the ones sold in Japan, which they are but until they were installed I was still a little unsure :/
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
