Cleaned up the engine bay a little. Painted some stuff black that looked out of place.
The more recent pics I've seen, It Looks Awesomer!!!
And yeah, bit of paintage changes lots. (I did some of this recently too.)
Today I drove it to work and back (as is the norm) expecting to still hear strange noises from my fuel pump in the heat of the arvo...
None came. Could it be that yesterdays tweakage fixed it? Oh baby I sure hope so !!!
If so, I'll be like :bunny: and then :banana: with a :D
Edited by Not a Pulsar
Ordered some Whiteline parts for the Stag which were sent yesterday from VIC, and arrived this morning! You gotta love the posties working OT over Christmas.
Bushes, rear sway bar and front sway bar links.
Today it's stick the OEM wind deflectors on the GTR.
Painted them gloss black and now fitting them without the little metal clips.
Just over getting rain dripping in when the windows slightly down.
I hate driving with all the windows up! cos I'm a smoker......
Shut da fK up
Shut da fK up
HOW DARE YOU SMOKE IN THAT CAR
Weather strips FTW !!!
Smoking = each to their own (I do)
But I quit smoking in my car like 4 cars ago. The rule is, only on road trips more than 200 kms.
Poor GTR forced to passive smoke. Makes Baby Jesus Cry. :(
Swapped ignitor with the unit Richard gave me for troubleshooting........misfire still present, however only doing it under DECENT boost now (whereas last drive it degraded to the point of doing it anything above vacuum, as well as on take-off). I suspect the original cause is now 'fixed' by swapping out my ignitor, however I think it f**ked my plugs lol. Damnit.
Normal bearing/seal etc gone in the old pump, nothing major.
Next SAU track day is probably the next outing.
thats good then
Installed poncams in my car today. It didnt take anywhere near as long as i expected. sounds mint and all ready for my tune tomorrow :)
which poncams?
interested to know the power figure?
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
