Also - was looking at a CF Pod Filter airbox - however it's rated for the stock pod filter and not my aftermarket one so not sure if it'll fit :(
What's a "Stock" pod filter? Stock airbox wouldn't fit some CBF heatshield so if it's for a pod, it should suit your needs.
So what is this Carbon dingus if it is for a stock airbox?
You are a perplexing little man. Do my f**kin head in you do. :P
http://justjap.com/store/product.php?productid=18017&cat=328&page=3
I like to speak in riddles :3
Pod Filter YES!
Stock Airflow Meter YES!
It is what you want. Untill you replace your Airflow Meter to get Extra Power. ie. Z32 Airflow meter.
And it's a Huge waste of monies.
My DIY Perspex one cost me $0.00
Oi Red - I have what you want - New :yes: still in box
It's the metal one from JJR (SRI)
- CF is shit. Ask a few of the lads on here. Flimsy, crack and break.
(it's better and cheaper Wooot! )
Edit: It is no longer any good for me as I have the Z32 and the metal intake pipe..
Edited by Sinista32
dude i told you dont worry about the pod filter it actully gives 0kw gains if not it just gives you more heat soak. The stock intakes are actually a nailed design. Ive been trying to convince him just to go without the certificate. Its not November yet the worst thing that would happen is that yo have to go again im not sure if you have a number of times that you can try to get cleared. Id be guessing three times.
"Facepalm"
B-rice is 100% correct. Don't waste your cash Jeremy. Start saving for a turbo for more POWAAAHH.
Like i said the only reason i have POD filters is because with the Z32 AFM a box will not fit. Soon i'm putting a haltech in, getting rid of AFM and going to E85 =). ARC induction box for me!
Edited by Anfanee
I buy what I like. I like CF, I don't care if it gives any sort of gain- the gain for me is visual as well as a bit of heat/cold air separation. I like the look of it. I don't see why it's a problem that I want to purchase something that I like? :/
How much is your metal SRI Richard?
  • Like 1
Meh... whats evs.
Buy Richard's and get some carbon look vinyl wrap.
Edit* under bonnet rice is pointless for you as it's only ever other people who lift your bonnet anyway. :P
$150
and I'm divided
I bet I could go around every ones skyline and spot mods with no benefits other than visual .........
Edit: This one https://www.justjap.com/store/product.php?productid=17670&cat=272&page=3
Edited by Sinista32
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
