Awesome! Looking good.
Thanks mate. I hope yours will get some TLC soon enough too.
Everyone's engines in the build up forum have been going in lately! good times! :D love the work, not long to go now! keep pedaling!
Yes, it engine build it up time ;)
Update time!
Went passed the workshop today and took some photos
just a random shot
Tomei expreme exhaust all bolted up
titanium rocks!
everything bolted up together nicely without any problems - pic of metal race catalytic converter
Midori Ti front pipe (sorry for the bad pic it was bright in the workshop)
Full picture shot of exhaust system - Nismo clutch, Slave cylinder and HPI clutch lilne also all bolted into place
Nice and clean (new) front diff and oil sump - for now
Next step is to start the car but few things need to be sorted out before hand - should be ready for dyno time before the end of this week :)
Ants! Come to the workshop and ill fit them :D
currently being fitted buddy as brakes are being bled and fluids replaced. But will no doubt have other things to do after car is running ;)
running and dynod yet??
all I can say for now is that its close..........very close................I am hoping to have some pretty groovy news............................today :)
  • Like 1
Who's tuning it Ant Eater?
ah............. so the word spreads fast around here re: nickname of my car (ant-eater) :D
Sean from EFI Performance is going to do run-in tune and will also be my tuner from there on.
  • Like 1
Bangen!!
What's the "target"? :D
after car / engine has been run-in, hoping for close to 370-380rwkw on 98.
on E85 - no idea?
forgot to mention that fuel pump has been replaced (due to old one shorting out) to accommodate E85 now and is now a 455lt/hr walbro fuel pump
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
