ah the ever dangerous "........for now"
can I just say power figure aside that torque curve is AWESOME!!!......
smooth drive and given the motor reliable as....
Im guessing that 350 on a "Run in " tune ?????
I'm thinking in 6 months this shit will get re-dic
Thanks mate. Not really certain you could say it was achieved on run in tune as Sean actually ran the engine in the dyno and then went for power run after.
Although there is no torque curve present in the dyno charts provided, the car is do easy to drive at low revs it's a pleasure to drive normally.
I've yet to put my foot down at SP1 cause
1. I'm trying to get my confidence back up again
2. There are no private roads I know of here readily at my disposal
you should do a private showing for the SAU Qld guys... happy to come along.. Epic Car.
Happy Laps at QR at the end of the month. See this thing down the main straight!
Dont forget to pack the scissors!
yep - looks great :thumbsup:
thanks mate.
Looks great mate!
thank you sir.
Congrats Anth!
Time to stretch her legs over a drive to Melbourne :yes:
lol will do.......but probably not Melbourne just yet.
i have to get used to driving this beast again.
few questions.
1. how is the car going????
2. what ever happened to your previous setup ???
3. where do you source you original stock nissan parts??
car is great mate.....................very easy to drive at low revs and sounds amazing!
I will have to post a vid of the car on start in the garage when I can.
I have some more restoration work to carry out on the car, but time right now is my biggest issue. I just dont have much (amazing what happens when you have more kids ;) )
Previous setup was sold a few months ago now to a bloke on the Goldie and hopefully is enjoying it.
fa
Most of my parts are usually sourced from Perfect Run Japan which do a great job.
Much better than any Nissan dealers here in Oz (sadly)
Anyways, here are a few more pics of the car I took quickly
fitted greedy radiator air guide - looks shiny ;)
Fitted Cusco front bumper number plate bracket with number plate - which was trickier to fit than I thought
have a really nice Tomei badge but not sure where to fit it - was thinking next or above the GTR badge - otherwise Im not fussed if I dont put it on
Ti exhaust system sounds really nice :yes:
More update soon guys
  • Like 1
coming out to happy laps mate????
Unfortunately, I will not be able to attend this one due to other commitments :(
But I will try my best to go to as many events as practicable ;)
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
