Shell is no go as she's in bad shape underneath
Thinking my car ain't that bad and may fix it.
Will see. Will just save more cash and buy a late model outright lol
strip shell.
take shell to bare metal.
reapir metal.
do some fancy shit. rebuild.
it needs to be done properly ants.
as you pull apart you write down whats broken....
strip shell.
reapir metal.
this ^ is whats on my mind and I can do it all in my garage
gonna be messy lol
but will look good once done
  • Like 1
lets face it these cars are showing there age and if you want to keep your R32 in good nick then your kinda better off stripping it all apart and then getting the right bits and pieces replaced especially the body.
its just the way things are with mother nature doing its thing and taking back its precious elements.
I still would like to see other BNR32 shells out there just to compare as so far I can tell you that its seems difficult to find one that is in a good state.
Acid drip to strip all the paint, replace any damaged panels with brand new. Stitch weld, 12 point cage. Electra dry carbon hanging panels painted body colour Because racestreetcar
almost. you may get away from stripping all the paint and only stripping whats necessary. only one way to find out.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
