Shell is no go as she's in bad shape underneath
Thinking my car ain't that bad and may fix it.
Will see. Will just save more cash and buy a late model outright lol
strip shell.
take shell to bare metal.
reapir metal.
do some fancy shit. rebuild.
it needs to be done properly ants.
as you pull apart you write down whats broken....
strip shell.
reapir metal.
this ^ is whats on my mind and I can do it all in my garage
gonna be messy lol
but will look good once done
  • Like 1
lets face it these cars are showing there age and if you want to keep your R32 in good nick then your kinda better off stripping it all apart and then getting the right bits and pieces replaced especially the body.
its just the way things are with mother nature doing its thing and taking back its precious elements.
I still would like to see other BNR32 shells out there just to compare as so far I can tell you that its seems difficult to find one that is in a good state.
Acid drip to strip all the paint, replace any damaged panels with brand new. Stitch weld, 12 point cage. Electra dry carbon hanging panels painted body colour Because racestreetcar
almost. you may get away from stripping all the paint and only stripping whats necessary. only one way to find out.
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
