Just orderd a set of front rotors for my gtr and they are way to big. The place i orderd them from are tllelling me that 94 model gtr came out with brembos not standard nissan calipers. My rotors measured up at 296mm.
Can anyone help me out with this?
Should my car have brembo calipers or did they order the wrong rotors?
Thanks, lozz
https://www.sau.com.au/forums/topic/416041-94-r32-gtr-brake-rotor-size/
They ordered the wrong rotors. According to the DBA catalogue, R32 GTR 08/89 - 12/94 use the 296mm rotor. Later models had optional Brembos.
Just send the rotors back and tell them you need the 296mm rotors (DBA cat 4926)
Not true, there trying to cover up there mistake obviously
Only the V-Spec models as mentioned had the Brembo's as standard, if they FASTED your VIN number before ordering then that would of given them right part numbers. If they did FAST your VIN and this is the rotors that are meant to be on it then i'd be real curious as possibly you own a V-Spec that someone has pilered the brakes off
Thanks guys. I read some where that gtst calipers and 33 gtr rotors fit with an adapter brack for the r32 gtst calipers made by gk tech. Are these rotors the same as the 33 gtr rotors? I can get a set of gtst calipers cheap and then ive got a cheap brake upgrade
Cheers, lozz
No. Not true. The caliper adaptors suit the R32 (and S14 and Z32) calipers which have shorter legs than than the R33/GTR calipers. The only "upgrade" you could do would be to get some old R32 calipers and the adaptors to use those 324mm rotors. But the R32 calipers are not as stiff as the later ones. They creak and groan and carry on like a pork chop.
There are not rally any decent options for spacing the R33/GTR calipers out to 324mm.
cheers
Im confused the legs on the calipers are longer on the gtr ir the legs on the hub? If it the calipers then i can swap them ouf for gtst one i can got for next to nothing. Are you saying its not a cheap upgrade worth doing because they creak and groan or do they flex to much and ruin the brake pedal feel?
Cheers, lozz
im begining to find nothing is cheap when it comes to gtrs
PRECISELY
Welcome to owning a GTR
Have a hunt around for a Brembo package for simplicity or if you have look in Group Buy section at moment there in final stages of the D2 6 and 4 pot brake upgrade packages
thanks mate. is there any cheap worth while brake upgrades for r32 gtr? im begining to find nothing is cheap when it comes to gtrs
cheers, lozz
I bought a front set of R33 GTR Brembo's, which are a direct fit on the R32 GTR,
A decent street setup.
Yeah you should go the D2 group buy. There is no such thing as a cheap brake upgrade for a GTR.
You'll want more than 324mm in the future anyway, those things are really hard on front brakes.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
