As we know the R32 N1s did not come fitted with a stereo. (It may have been an option?)
Can anyone with a N1 confirm if the wiring for a head unit or speaker is present in the factory loom or not?
most of the boyz here that have a genuine N1 actually have the radio optioned in. So, I doubt you will find your answer here.
I think there is a fellow on the GTR Canada forum that has one without the radio, but not sure if hes on there anymore.
Working in the automotive industry - I can say that wiring looms are complex items and it is often easier to have one loom with empty connectors then different looms for different grades of the same car.......
I for one would be surprised if they made a different wiring loom for the N1 - considering that at the point in the line where the cars are modified (no rear windscreen wiper, A/C etc.) the loom would already be in the car. Also it would be virtually impossible to provide a different loom for those N1's were no radio was optioned (comparedf to N1's with radio optioned in).
I'd be 99.99% certain the connectors exist.
Cheers
The not 100% though Baron
Cheers
This is true. Other than a few extra loops of tape to secure the extra wiring, a few clips and blank receptacles for the connectors to seat into, the loom is identical.
Regards, Auto Electrician and N1 owner Adrian :)
Here is a pic of the wiring in my N1 that i took on the weekend. SO it looks like at least my N1 has factory stereo wiring. I cannot confirm or deny if my car came with a stereo or not, as when i got it, it had an aftermarket head deck in it.
R32 GTR N1 Stereo Wiring
Cheers
Thanks fellas. Good practical logic going on there.
I think we can conclude that all BNR32 looms are the same irrelevant of model variant. At least from factory anyway.
Hello All,
I'm back after the mishap at SAU trackday..... managed to get my hands on a black R32 GTR V-Spec. I'll post some pics soon once I get the blue slip sorted out. Car has just over 70,000km on the clock.
Chassis: BNR32300254
Model: KBNR32RBFS AA
  • Like 2
Hello All,
Is that the QLD car?
If so, it was for sale for ever but looked a great buy.
Could never work out why it didn't sell until now.
Where are you located? We need a V-Spec get together in Sydney!
Bob.
Hey Bob,
yep...its the one from QLD. It took a while to sell as I was getting a few mates to check the car out for me. Wanted to make sure everything was good.
I'm in Peakhurst Heights. We spoke briefly at the 25th Anniversary.
Definitely keen for a V-Spec meet up.
No worries. There was a dark coloured V-Spec or V-Spec II on Carsales in Queensland when I bought mine a couple of years ago. REALLY NICE. The owner had spent a bit replacing worn bits.
Always wondered what happened to it.
was that the 93 VSpecI for about $36K??
I seem to remember one being on there for ages.......
Hello All,
Sorted out the blue slip and rego, washed and polished the car, changed over the rims and installed the lower side skirts. AC belt snapped due to tensioner bearing failing....still drivable though
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
