not completely true. Its different to air.
Pressure IS pressure, it dont matter if your pump flows 8KL at redline if you have a certain size restriction, with same oil, and same pressure, the flow will be identical. The only time flow of pump counts is at idle when relief valve is shut. If both are set to certain pressure both will move the exact same at full revs.
Having one at 75 and one at 70 psi the higher pressure does mean more oil flow, through pressure, not pump capacity. If this makes sense
Well said.
Lets ignore the case when the pressure relief is seated because that is at low rpm where no one really cares and it complicates the explanation.
The point is if there are two pumps with different sized rotors etc and similar pressure relief arrangements they will flow the same amount through the same motor given the pressure relief measurement is the same.
Oil pressure is a measure of how hard it is to pump oil through a system. It is not a pump property.
  • Replies 58
They are still both fluids, so the principles are the same. I was only refering to the pump itself, not the whole system...so it was a just a bad analogy on my behalf ;)
This is correct and why i was asking about the upper operational pressure of the oem pump...if it's running at 120psi at 8000rpm, why can't you run the nitto at 120psi?
Edited by wedge_r34gtr
120PSI at 8000 is a little different to 120psi at IDLE. High pressure isnt uncommon with these so im not sure why this is still being discussed to be honest! The only issue with such high pressue is blow through on the turbo and filling the head with oil however if all the necessary things have been done during the build then no issues...
Does a stock one push 120? If it did, it would be exacly the same as a nitto or tomei with the same pressure. That much pressure is excessive regardless. Might not 'hurt' anything in the short run, but you dont need that much pressue
No pump will do that anyway
no stock wont push that much pressure but i have heard N1's doing this kind of pressure on idle and blowing oil straight out the turbo. Giving this is a built motor you would assume that necessary breather/catchcan setup has been made and even a drain from the head? i dont really see an issue if its setup right from the start
can always reduce oil flow to the turbo also
yeah...i think we can continue the discussion with engines that are built correctly in mind...
*sigh*
Pressure is restrciction to flow.
Think about a garden hose with no end on it, water runs out. Put your finger over the end (i.e make a restriction) and the water shoots out at a higher pressure
More pressure often equals less flow, but its not that simple as in they are not directly proportional (from memory). But at no flow you would hit the pumps relief setting so you would get maximum pressure at minimum/no flow
so if i have a pump running 80psi, then up the pressure to 120 i will have less oil in the head ? i think common sense would say the opposite. op the more pressure u have the more pressure u have with held in the system, and the more oil will be in the head. just like u said.
correct this is a built motor and will be running a catchcan to sump, breathers, and also a crack case vent to top of catchcan, engine had mods done to the oil returns that have been enlarge, also when the motor was been built with the nitto pump, engine builder was worry about the 120psi (he said its fine if its a drag car revving its tits off) anyways its set atm with 1 spring and 1 shim he said with the clearances and the oil he told me to use i will be seeing around 80 85psi, he also recommand the high volume sump (which im getting) coz it will suck the standard one dry...
(also gotten the same response from two different engine builders today about the high 120psi) infact one told me to remove 1 spring and to put 2 shims in to give me a total of around 80psi....
anyways the higher pressure more oil, fitting restritors to turbo isnt a worry i already know this would be need with a high pressure pump,
only thing i was trying to sort out was if i had a tomei pump on 75psi a nitto pump on 75psi would the oil flow be the same? as i think the nitto gearing is bigger then a tomei pump (could be other way around) wouldnt the nitto pump supply more oil flow at the same psi?
The restrictors have two main purposes: Keeping oil pressure in the block and preventing to much oil getting in the head
What I'm reading into your post there is you want to change the pump relief pressure from 80 to 120psi. This will not mean less oil in the head. You are not changing the restriction but rather exchanging how much pressure the oil will pump. So you still have (for example) a 2mm hole to feed oil into, but instead of only supplying enough oil to hit 80psi, the pump is supplying enough oil to hit 120psi. Therefore there is more oil displaced from the pump before it is hitting relief.
You need flow to move oil, you need flow + restriction to create pressure, pressure and flow will increase proportionally if the restriction is not changed.
Change the restriction however to a 1mm hole then you should hit 120psi with less oil being displaced
Will be exactly the same. Tomei has bigger gearset I believe
Rob from rips in newzealand Does not use any oil squirters in any of they rb30/25 26 engine combos no matter if its street use or drag
Yeah, because there are no oil squirters to use in the first place...
Engine builder has told me to use penrite running in oil, do about an hours worth of driving not boosting it keeping eye on oil levels, drop the oil, fill again with same running in oil, another hours worth of driving, drop oil and put in hpr30, what's the thoughts of this?
I thought synth, but he told me not to use synth oil or the motor will go bang, not to use synth oil with the acl h series bearings, my clearances are 2.3tho
Use penrite for running in.
This is how i ran my engine in as advised by my builder:
In your garage start the engine - don't let it idle and vary the engine rpm between 3-4000rpm (small amounts of boost are alright...say <3psi) for about 15-20mins or until fully warmed up. inspect for leaks excessive blow by etc during this period
Shut off. drop oil and inspect for issues. Drop filter - cut open and inspect for metal. Refill with penrite & replace filter - go out and do an hour or so worth of driving keeping off boost and varying load (using 1st, 3rd and 5th to drive around is a good idea) If possible, have someone doing some rough road tuning on your ecu. Drop oil and filter and re-inspect. Drive to tuners if no problems.
  • 6 months later...
What is the purpose of your question? Crank collars are all the same about 43.7mm diameter or 40.7mm at the flats and all oil pumps for RBs are made to suit.
My question is, and albeit i have looked and googled and contacted nitto with no success. What is the clearance tolerance for the nitto oil pump to the collar.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
