Scandy - glamped refers to glamourous camping, which is the best description for tenting in a caravan park (ie toilet & shower facilities).
Imo that's not camping, but rather glamping. It's only camping when you've got to dig a hole for 'sitting' on.
Now.... Swisse advert on tv with Ponting batting in the nets. What's the song?
You mean that Ad?
I'm well aware of the concept of 'glamping'. I just find the word to be utterly ridiculous.
the missus put me onto it, lol.
hadnt heard of it until last week ;) makes sense tho.
Its good you clarified that, cause I'm sure a bunch of folks thought it meant Gary Glitter in a tent.
Kids can now camp in caravan parks, assured of their safety...
-D
If anyone cares Fast and frivolous 6 comes out may 24 and they wreck new mustangs, ferrari , chevy muscle
The silver r35 is back too
Filmed in UK and Germany
All the old cast and "the rock " is still chasing Dom
Plenty of new spicy hot chicks as well
Trailers out on youtube
Also announced F&F 7 !!
Be fun to cruise to drive in when the time comes ?
Even if you think its cheesy ,it still fun / worth watching instead of another Romcom
Edited by Carbon 34
wheres the 'real' trailer? all i see is 8 month old fake trailers haha
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
