My radiator heater tank is leaking, and the rest of my radiator isn't looking too good either, so I'm looking to buy a new one. Where's a good place to look?
I have a s1 r33 gtst
Thanks in advance guys!
got my radiator from ebay. perfect fit and works great.
Really if it is leaking and in bad shape then you need to get it replaced ASAP. Just head to a radiator shop...
Go see the guys at Holden Hill radiators or someone similar. They have Koyorad and Adrad usually in stock and can fit them pretty quickly.
Even go a thicker core while you are at it :)
The ebay ones can be hit and miss. Do you really want to entrust one of you engines most critical processes to something that is not of a certain quality.
Well that is how I think...
Woops my bad - should have posted this here: My apologies to the mods.
I'm doing a suspension mod and need some 3/4 bright mild steel rod. Where can I buy this stuff from in Adelaide. Preferably southern Adelaide...
Google comes back a few results, all of which are NFG. If only JB Cameron's or somebody would open in Adelaide... There must be an equivalent ?
Thanks!
Jeff
We've put ebay alloy rads in 4 cars now, and they are all great. Put a 50mm dual row in the R33 the other week as the plastic top hose nipple was cracking in the original - was a tight fit but no problems. I think it was around $150 shipped. Had to mod the intake snorkel slightly to clear the radiator, but other than that it bolted straight in.
Jeff here's a couple southies that you may have already tried
Basic Steel
40 Raglan Ave
Edwardstown
(08) 8297 9577
Southern Steel Supplies
southernsteelsupplies.com.au
69/71 O'Sullivan Beach Rd
Lonsdale
1300 561 178
Hey Pete, remember at Kadina I was telling you about how I was mining Bitcoins and all about the whole alt-currency concept? Well back then a Bitcoin was worth just over US$100 - they are about to crack US$1,000 per Bitcoin!!!!!
http://bitcoincharts.com/charts/mtgoxUSD#rg180ztgSzm1g10zm2g25zv
Luckily I have a few :ninja: - but not nearly as many as I would like. Sadly in July I decided that the electricity cost and hardware depreciation was not justifiable at around US$100 per Bitcoin - I was only just breaking even. Wish I had a time machine now!
But I wouldn't be nearly as sad as his guy (I think I told you this story back then).
http://motherboard.vice.com/blog/this-pizza-is-worth-750000
But update the price of that pizza to around US$9M now!!!!!!!!!!!!!!!!!!!
Wow...should've listened to you bud! :/
The running costs and constant supervision freaked me out a little but yeah, in the same vein, I wish I bought a whole bunch of properties at the turn of the century.
With the massive property boom we've experienced, I'd be a squillionaire now!!
Might try and invent the time machine I reckon :w00t:
what.......you mean you are not :P
Just make sure it's a nissan time machine.
that'll need a rebuild :P
So - 2nd Yr Radiaton Science completed.
Yay!
Just a few weeks of clinical placement, then some time off.
Seems just the other day that I woke up one morning on rock bottom (when I probably shouldnt have continued breathing), decided to change for the better & went cold turhkey off the Duragesic - a hard core opiate med, got into a course with a 99 TER a couple of months later, and now half way there to a satisfying career.
Should have bought bitcoins tho :/
  • Like 2
Thanks!
Jeff
Interalloy @ Cavan. We use them for all our round bar in our machine shop. Im assuming it's for adj. arms of some description?
I find that whole Silk Road thing so interesting. I wonder if another one has opened?
Congrats Brendan - you must be loving life!
Oh, and http://www.pcauthority.com.au/News/365851,bitcoin-soars-past-1000.aspx?eid=19&edate=20131128&utm_source=20131128&utm_medium=newsletter&utm_campaign=daily_newsletter&nl=daily&[email protected]
There must be literally tens of thousands of instant millionaires this week.
Still going to probably head out for a boot if anyone else is out tonight...
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
