hey, Question - how can you tell when you require a new thermostat?
Going to do a service in a couple of weeks time, RB25det is a fair bit sluggish prior to warmup these days.
In the old days I used to take it out and put it in a kettle with a thermometer and watch the temp on the thermometer and see when it opened or activated the circuit.
Not perfect but it always let me know if it was working properly...
Also it is a thermostat... $35 to $40 just change it lol ;)
when your car overheats.....
they're not expensive so if its old just replace it.
Oh ok, Thx guys. Car doesn't overheat, radiator is pretty fresh. Due for my home service, and probably needs the timing checked. Can't afford dyno time, still :( just sluggish on cold start....
Mobilecouch - see Shaun Dunns at Boostworx, or Martin Donnan at Willal racing.
had my powerrun done today at willall -160kw @4psi and 180kw @ 8psi
i enquired about the ecu while i was there. they said that because it's an "older" skyline that they'd charge more to get the work done but they'll tune it once ive finished modding. meh.
ill give boostworx a call on monday.
can anyone recommend a workshop in adelaide that sells and fits a z32 ecu with nistune to suit a rb25det?
Jaustech brother, tell them Wayne sent you :)
Address: 13 Jacobsen Crescent, Holden Hill SA 5088
Phone:(08) 8266 7244
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
    • Not yet quite as bad as what we've seen a Jim Berry clutch do in an R32 GTR though when it decided to cut a chassis rail in half... Still very very gnarly and a great reason to avoid.
