They sell springs separate to coilovers because before the sudden influx of cheap Chinese/Taiwanese coilovers, such things were the province of race and rally cars, were expensive, rebuildable, completely adjustable and so could be set up any which way you liked. For a price.
^^ Agree. Buying springs individually is for people with quality shocks, DIY, and those with a good adjustment (separate bound/rebound). Also people might go a have a 7kg and have a 6 and a 8kg sitting on the shelf to tweak the rates for different tracks, front/rear bias, etc.
As mentioned, I wouldn't go higher than 6/4 for street. At the moment in my GT-R I'm running old TEINs (no damper adjustment), which I estimate are around the 7-8kg/mm mark. Very good for corners, but for Sydney roads they are way too stiff.
My Ohlins with Eibach springs on the other hand, I estimate them to be around 4-5kg/mm, a lot more comfortable but still decent for handing, has body roll though (softer compression on the Ohlins compared to the TEINS). Nismo S-Tune spring rates apparently are 5.3/4.8 for the R33 GTS-t.
If in doubt, get these: http://www.otomoto.com.au/p/8475209/hsd-ad-type-coliovers-for-skyline-ecr33.html, 7/5 kg/mm with damper adjust. Good for full weight Skyline that you will track occasionally IMO.
A lot depends on how much harshness you can tolerate. I'm seriously considering going back to my Ohlin/Eibach suspension as the TEINs are just too harsh for Sydney roads (35 series tyres don't help either :P).
A mate of mine got the Blitz set from Just Jap for his S14. They are 8/6 but more comfortable than my TEINs. S14s are obviously lighter as well. Food for thought.
  • 1 month later...
Im in need of some expertise with my set up, currently have http://www.nengun.com/cusco/zero-2-suspension With what im told are aftermarket springs of what he thinks are 16/18 or something stupid...
There is no one really replying in the "what is my spring rate thread" so what are the options with changing signs, Just get the right diameter to fit an prick the rates i want?
gawddamn sorry always get them mixed up
so while i'm here, can i get some mine's eibach springs from a GTR set of shocks, and stick them on a set of Bilsteins for my GTT?
And where does everyone buy their springs? I only know Pedders n King Springs here in Sydney. Does the diameter have to be exact in mm to sit on the coilover, its pretty hard to measure it with the spring in-car
Yes the diameter has to be right. But, they're supposed to be all the same. Something like 60mm internal diameter, or whatever it is supposed to be.
The places to talk to about springs for coilovers are the DECENT suspension shops (which counts out Pedders). There are examples everywhere. Places like Drummond, MCA, etc, that suspension setups for race cars and so on.
Look up K-MAC in Rockdale
Thanks guys, got verniers today n worked out my spring rates from web calculators at 10.7/9 or 11/9- way too hard. Even going down to 9/7 will still be hard I reckon.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
