They sell springs separate to coilovers because before the sudden influx of cheap Chinese/Taiwanese coilovers, such things were the province of race and rally cars, were expensive, rebuildable, completely adjustable and so could be set up any which way you liked. For a price.
^^ Agree. Buying springs individually is for people with quality shocks, DIY, and those with a good adjustment (separate bound/rebound). Also people might go a have a 7kg and have a 6 and a 8kg sitting on the shelf to tweak the rates for different tracks, front/rear bias, etc.
As mentioned, I wouldn't go higher than 6/4 for street. At the moment in my GT-R I'm running old TEINs (no damper adjustment), which I estimate are around the 7-8kg/mm mark. Very good for corners, but for Sydney roads they are way too stiff.
My Ohlins with Eibach springs on the other hand, I estimate them to be around 4-5kg/mm, a lot more comfortable but still decent for handing, has body roll though (softer compression on the Ohlins compared to the TEINS). Nismo S-Tune spring rates apparently are 5.3/4.8 for the R33 GTS-t.
If in doubt, get these: http://www.otomoto.com.au/p/8475209/hsd-ad-type-coliovers-for-skyline-ecr33.html, 7/5 kg/mm with damper adjust. Good for full weight Skyline that you will track occasionally IMO.
A lot depends on how much harshness you can tolerate. I'm seriously considering going back to my Ohlin/Eibach suspension as the TEINs are just too harsh for Sydney roads (35 series tyres don't help either :P).
A mate of mine got the Blitz set from Just Jap for his S14. They are 8/6 but more comfortable than my TEINs. S14s are obviously lighter as well. Food for thought.
  • 1 month later...
Im in need of some expertise with my set up, currently have http://www.nengun.com/cusco/zero-2-suspension With what im told are aftermarket springs of what he thinks are 16/18 or something stupid...
There is no one really replying in the "what is my spring rate thread" so what are the options with changing signs, Just get the right diameter to fit an prick the rates i want?
gawddamn sorry always get them mixed up
so while i'm here, can i get some mine's eibach springs from a GTR set of shocks, and stick them on a set of Bilsteins for my GTT?
And where does everyone buy their springs? I only know Pedders n King Springs here in Sydney. Does the diameter have to be exact in mm to sit on the coilover, its pretty hard to measure it with the spring in-car
Yes the diameter has to be right. But, they're supposed to be all the same. Something like 60mm internal diameter, or whatever it is supposed to be.
The places to talk to about springs for coilovers are the DECENT suspension shops (which counts out Pedders). There are examples everywhere. Places like Drummond, MCA, etc, that suspension setups for race cars and so on.
Look up K-MAC in Rockdale
Thanks guys, got verniers today n worked out my spring rates from web calculators at 10.7/9 or 11/9- way too hard. Even going down to 9/7 will still be hard I reckon.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
