So, Dale spec brace went in. Highly advised to do this with caster bushes and swaybars best shit ever.
My rotors finally arrived and now I'm just looking at what rubber to get I'm aiming for falken 452 in 245/45/18.
Now I've won a few goodies on YAJ :D:D.
active20120801-img600x450-1365906105gsed
Nismo anyone??
urawakaitai-img600x450-1363661832hy86t91
Bilsteins with braces :D.
active20120801-img600x450-1365909307prs7
KaKamoto R, its got a dent in the muffler but I think I can get it out somehow.
HEHEHEHE super excitied. The bilsteins are being sea freighted so will be a month or two, everything else I will possibly get earlier.
All that's left is cat's, shift kit and trans cooler then I think that'll be all?? Anything that I've missed?
https://www.sau.com.au/forums/topic/417327-my-pnm35/page/4/#findComment-6824084
Not sure. Could probably check though, I have a Dolphin one. Cost was only $200 or so through Streeter. Honestly, I'm not sure on the performance gains. It makes only a slight difference on mine, given I've got Dale's lower brace, Whiteline sway bars, BCs and full SuperPro bushes.
https://www.sau.com.au/forums/topic/417327-my-pnm35/page/4/#findComment-6824752
You forgot to mention the Nismo oil cap Ryan. That's worth a 1/10 on any circuit, lol.
https://www.sau.com.au/forums/topic/417327-my-pnm35/page/4/#findComment-6824998
mmmmmm......
It's my favourite part of going to work!
I love the little game I have with myself when parts arrive!
1/ Random parts rocks up!!!
A/ Whats in the box before I open it?
B/ When did I order it?
C/ What did I need it for?
D/ Did I order it for me?
  • Like 1
https://www.sau.com.au/forums/topic/417327-my-pnm35/page/4/#findComment-6825764
Nice parts Matt.... just for reference though, the Nismo springs are from the 2WD Stagea so are a little different than the NM35 springs although I'm sure just as nice (I was looking at them to put with my Bilsteins :))
AWD - F 8.3kg/mm
AWD - R 9.2kg/mm
2WD - F 7.5kg/mm
2WD - R 9.4kg/mm
https://www.sau.com.au/forums/topic/417327-my-pnm35/page/4/#findComment-6831126
Ah! Caught out! Is that because of the slight weight and distribution difference?
Cheers for the info Cam. Ill give them a go, main thing though, they will fit?
Yep, due to weight distribution.
I can't see why they wouldn't fit. Pretty sure that others have had the same springs on NM35's in the past without issue.
https://www.sau.com.au/forums/topic/417327-my-pnm35/page/4/#findComment-6832084
  • 2 months later...
FFS! this is the third time of trying to post in my own thread FU*K.
Most of you know I've got the Bilsteins on with the Nismo springs and the kakimoto zorst, I've got the V35 18's on wrapped in Falken 452's 245/45/18 HELLACHUNKYPLS, oh and a rear underbody brace.
(thanks to the help of Alex) He found that the radiator is weeping so replacement hoses, belt and a radiator are coming.
So all I gotta do now is do my brakes and my handling is done :D.
To Do List:
Trans cooler
HFC's
Transgo shift kit
Finished.
How she sat.
How she sits.
Shoulda came out from factory just like this.
Edited by M35woah
https://www.sau.com.au/forums/topic/417327-my-pnm35/page/4/#findComment-6928169
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
