So, Dale spec brace went in. Highly advised to do this with caster bushes and swaybars best shit ever.
My rotors finally arrived and now I'm just looking at what rubber to get I'm aiming for falken 452 in 245/45/18.
Now I've won a few goodies on YAJ :D:D.
active20120801-img600x450-1365906105gsed
Nismo anyone??
urawakaitai-img600x450-1363661832hy86t91
Bilsteins with braces :D.
active20120801-img600x450-1365909307prs7
KaKamoto R, its got a dent in the muffler but I think I can get it out somehow.
HEHEHEHE super excitied. The bilsteins are being sea freighted so will be a month or two, everything else I will possibly get earlier.
All that's left is cat's, shift kit and trans cooler then I think that'll be all?? Anything that I've missed?
https://www.sau.com.au/forums/topic/417327-my-pnm35/page/4/#findComment-6824084
Not sure. Could probably check though, I have a Dolphin one. Cost was only $200 or so through Streeter. Honestly, I'm not sure on the performance gains. It makes only a slight difference on mine, given I've got Dale's lower brace, Whiteline sway bars, BCs and full SuperPro bushes.
https://www.sau.com.au/forums/topic/417327-my-pnm35/page/4/#findComment-6824752
You forgot to mention the Nismo oil cap Ryan. That's worth a 1/10 on any circuit, lol.
https://www.sau.com.au/forums/topic/417327-my-pnm35/page/4/#findComment-6824998
mmmmmm......
It's my favourite part of going to work!
I love the little game I have with myself when parts arrive!
1/ Random parts rocks up!!!
A/ Whats in the box before I open it?
B/ When did I order it?
C/ What did I need it for?
D/ Did I order it for me?
  • Like 1
https://www.sau.com.au/forums/topic/417327-my-pnm35/page/4/#findComment-6825764
Nice parts Matt.... just for reference though, the Nismo springs are from the 2WD Stagea so are a little different than the NM35 springs although I'm sure just as nice (I was looking at them to put with my Bilsteins :))
AWD - F 8.3kg/mm
AWD - R 9.2kg/mm
2WD - F 7.5kg/mm
2WD - R 9.4kg/mm
https://www.sau.com.au/forums/topic/417327-my-pnm35/page/4/#findComment-6831126
Ah! Caught out! Is that because of the slight weight and distribution difference?
Cheers for the info Cam. Ill give them a go, main thing though, they will fit?
Yep, due to weight distribution.
I can't see why they wouldn't fit. Pretty sure that others have had the same springs on NM35's in the past without issue.
https://www.sau.com.au/forums/topic/417327-my-pnm35/page/4/#findComment-6832084
  • 2 months later...
FFS! this is the third time of trying to post in my own thread FU*K.
Most of you know I've got the Bilsteins on with the Nismo springs and the kakimoto zorst, I've got the V35 18's on wrapped in Falken 452's 245/45/18 HELLACHUNKYPLS, oh and a rear underbody brace.
(thanks to the help of Alex) He found that the radiator is weeping so replacement hoses, belt and a radiator are coming.
So all I gotta do now is do my brakes and my handling is done :D.
To Do List:
Trans cooler
HFC's
Transgo shift kit
Finished.
How she sat.
How she sits.
Shoulda came out from factory just like this.
Edited by M35woah
https://www.sau.com.au/forums/topic/417327-my-pnm35/page/4/#findComment-6928169
    • Dose will be able to confirm this more, but a 1.5 way IS a 2 way. It's just not as aggressive on one of the ramps. Changing from 2 to 1.5 I'm not sure how though.
    • No updates on the car but figured I'd share a nice outing. All the recent work paid off and I got it all together and out the shed for a car based pre-wedding celebration for a good mate of mine. Pretty casual cruise through the hills to a pub for lunch then out for some go-karting at The Bend. Headed down to Myponga for the night We stopped in at the reservoir before heading out down to the coast for lunch via the dam  By the end of the weekend away I covered 350km and the 32 generally behaved its self. A good Shake down after being apart before the Track day in a few weeks
    • The front prop shaft from my GTR had very notchy unis, which obviously needed replacement but unfortunately uses the (usually) non-replaceable (staked) type.     A new shaft is something like $2K plus shipping from Japan.   I wouldn't even bother asking the local Nissan spares dept.     Rang Hardy Spicer but no go, which surprised me a little.     There's a place over Dandenong way that would make me a 'performance' shaft but un-necessary in my situation.   They claimed to be getting the equipment in to replace staked unis but couldn't give me a timeframe.   Anyway, long story short, found a place to do the work just 5 mins from me: https://knoxdriveshafts.com.au $420 (cash) and about a week later I have my driveshaft back.   Price includes balancing. Owner is a one man band working out of a shed in his backyard but from what I could see he's very well setup with some expensive equipment.
    • Thanks. That's what I was after. One of the kits, the o-ring side is too big diameter. The other kit is a plate with a o-ring to seal and the hose connection offset.
