Hey,
I've got a S2 RB25DET and i'm basically chasing 300rwkw. As for mods i'm not 100% sure on what i'll do, I'm after opinions on what would be a succesful way of reaching my target.
Rough idea:
Spitfire coilpacks
Tomei Poncams
Tomei adj cam gears
555cc injectors
Walbro fuel pump
Pod filter ( already done )
Fmic ( already done )
Front facing plenum
3inch turbo back exhuast with hi flow car ( already done )
Nismo fuel reg
Nismo oil pump
I'm unsure of turbo setups to run, I want something responsive with a decent power output i have a few in mind but please opinions, and also the same for ECU, this is the first turbo car i'll be modifying and its going to be a build and opinions would be nice. I know i'll need a good tuner aswell
As i said i'm chasing 300rwkw, twin plate clutches would support that?
Edited by skyline32sup
https://www.sau.com.au/forums/topic/417658-rb25-chasing-300rwkw-opinions/
How much are you prepared to spend? You can go from reasonably responsive 300-ish kw all the way to ultra responsive 300+kw and spend a very different sum of money.
An outright optimal 300kw setup would feature 6boost twin scroll manifold with twin wastegates, EFR7670 turbo, G4 Link ECU with Link boost control, a set of ID1000s and a Walbro E85 friendly 400+lph fuel pump. Then you could go E85/flex fuel and make well over 300kw...
Hey,
Rough idea:
Spitfire coilpacks
Tomei Poncams
Tomei adj cam gears
555cc injectors
Walbro fuel pump
Front facing plenum
Nismo fuel reg
Nismo oil pump
if your in brissy you can use eflex, so forget the 555's and go 1000's, you could basically copy my setup without the gtx, cams and external gate.
a 3076 with 0.63 on eflex for maximum response and hit the 300kw.
Edited by AngryRBGTX
If you MUST get 300rwkw on 98ron then a 3076 (56 trim) 0.82 is the minimum you will need. Even then you might not get there and depends on dyno as much as engine/tune. If you get a good exhaust manifold and use an external gate then you'd be more sure of making the magic number, but you'll still need the 0.82 and 1.3 bar.
A stock engine will last OK for street use, occasional track days and depends on how you use it/abuse it.
Also need 600+ cc injectors, perhaps the 740cc Nismo to allow E85 use in future?
I've got some side feed 880cc injectors and a 3076R .82 about to be hitting the for sale thread.
They are off my RB25 which was making 306kw at 16psi. Std plenum, std cams, 3inch exhaust.
Pm me if interested.
Pretty good power at 16psi, who tuned it?
I've got the 3076 on mine, with 555cc making 275rwkw, hoping 1000cc and a hiflow cat can get me 300 without e85
555's are enough for 300kw, probably not the issue, mine was limited to 280kw, tuner said some rb's can take more timing and others cant so dont expect things to change just like that, but obviously the exhaust must flow well..
It was Unigroup or Jem, pretty sure Unigroup. I saw the dyno sheet when I bought the car off the previous owner.
Will be hitting the dyno again sometime next month once.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
