We have been using a Motorsport systems strain gauge. I flat shift 3rd to 4th and clutch other gears, not sure how dean our driver does it, I'm still learning so I was advised to only flat change 3rd to 4th. I messgaed Ex bsm to find out what happened few days ago but no response as yet.
This was the recommended and only way ;) now Incorporate the ikeya shifter somehow!!! :P
Shared a garage with the sigworth car last year at wtac.. certainly not your regular backyard crew.. Was very well oiled and everyone seemed to have a place,... Times improved every session but testing was lacking from what I could see... Didn't realise how quick the QR times were... Pro Am seems to be the right class! (Phew) :)
Probably be free for those guys
Looks awesome the car list so far
Throw a time attack car in for a laugh
Set of AD08s coming next week for some random testing in the weeks to come
Did you pick up the tires locally with the wtac deal?
Where u testing? Should tee something up when I'm ready !
Nah no info on the deal but I shopped around and found a place which had stock, and only set me back $375 a tyre!! So well under the price Yokohama have on their website
Probably go Wakefield for a day then get out to EC when the tuner has his Evo ready and his pro driver gives me tips hahaha
If anyone is interested there is a set of 265/35/18 AD08s for sale brand new for $1500
Same guy i went to get mine today
If you are interested give Tyres & More Wetherill Park a call
He has one set left and there is not alot of stock in sydney nearly 0!!
For a reference point as I'm not familiar with the track, what kind of lap times would the pro class drivers of last year do, ie mark berry gtr 34, or even his 32 and other drivers?
I noticed the byp integra is up there's with em, is the circuit more like Winton? As in better suited to light weight cars that handle than overall power if you get what I mean.
That front diff and transfer case Richo put in is doing the job :)
ah noooooooew.
We ran out of fuel!!! Ended up with a 1.04.9. Had a low 1.04 in it, but wasn't to be.
Huge challenge even to make the event. The old man and my brother put in a big effort.
In the weekends leading up to it we dropped a heap of weight, did heaps of maintenance to suspension bits, changed the diff (mine is broken, no time to fix), borrowing brake pads on Monday night (i was working in sydney tues-fri) and in the days before get a wheel alignment and new tyres (on Friday).
At a track I'd been too once before, with tyres I'd never run before (z222 285/35), with no ABS (borrowed diff was a non ABS unit) we ended up 4th in Club, so very close to 3rd.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
