Hi all, got a few queries with the instal of my plasmaman,
Firstly, I think I have a fairly old one, I got in second hand with t/b, reason I think that is it has an adapter place for aac valve instead of it bolting to side of plenum.
What I need to know is where to plumb things basically.
I run a haltech map sensor, To shorten the feed hose length should I tap into engine side of plenum half way up?
Where do I run the little hose that goes to the carbon canister from stock t/b?
Where do I plumb my pcv into?
Where do i get pcv from rb26 covers?
Im sure theres more ill think of but this is the main bits. Couldnt find much on the forums about these...
Thanks
https://www.sau.com.au/forums/topic/417808-plasmaman-fitment-questions/
Hmmm, my Plazmaman has like 7 fittings underneath.
Adapter plate is a little odd. The R33 IAC should bolt up to the rear of the Plazmaman? Unless the customer who ordered asked for something unusual like i did with mine... However, early models could have been done like this. I dont know.
If the MAP sensor is a 1/8" NPT thread you should be able to thread it into the Plazmaman directly.
With the PCV and RB26 covers, you'll have to custom make something. The PCV on an RB26 is on the balance tube of the inlet plenum. You'll probably want to have the LH rocker cover going into the turbo intake and the RH going into the Plazmaman via the PCV one way valve.
The little hose that goes from the carbon canister to the factory throttle body is a good question. I would also like the answer to this as i'll need to know eventually as well. I would dare say, it will need to go to the intercooler pipe just before the throttle body.
The larger pipe from the carbon caniser is plumbed directly to the plenum as well.
If you only have 3 fittings, before fitting the plenum maybe its a good idea to drill and tap some more holes in it.
You need provisions for:
Brake Booster
Fuel Press Reg
Carbon Canister
PCV
MAP Sensor
Boost Guage
Thanks kitto, ill have to tap fittings in at appropriate places.... id think the carbon canister tube off stock t/b goes to engine side as it'd actuate the diaphram in canister to suck on vacuum/close on boost?
This is my theory as well.
But if you have a look at where that little hose goes to on the throttle body, the hole pops up just barely on the intercooler side of the throttle body...
You can get manifolds with lots of takeoffs for various vacuum functions so you don't have to turn the plasmaman into a colendar.
Like this (some screw into the plenum some are just connected with a hose):
http://www.ebay.com.au/itm/ADD-Universal-Vacuum-Manifold-turbo-boost-vacuum-wastegate-intake-manifold-/110993986088?pt=Motors_Car_Truck_Parts_Accessories&hash=item19d7c1d228
And don't most people just bin the carbon canister?
Its not the smartest idea to delete the Carbon Canister. The only annoying thing about it is that it takes up space.
The larger tube is connected directly to the plenum, this is where the vapours enter the engine from the canister.
The smaller hose is to open the one way valve under vacuum and light throttle conditions. Why it is placed exactly where it is on the tip of the throttle plate i am unsure.
On R34's there is a solenoid inline with the small hose. From the canister the small hoses goes to the solenoid valve, then to the plenum. It's operated by the ECU. Obviously the ECU chooses the best time to open the valve. IE, the valve is open all the time until atmospheric pressure and above is reached.
Sounds like it may not be a plazmaman and instead one of the chinese knock offs?
Definately a plasmaman. just has 3 1/8 bsp holes near t/b and 1 3/8 bsp toward back for aac valve. Might tap 1 in middle for map and plumb booster into aac line
Brake Booster
Fuel Press Reg
Carbon Canister
PCV
MAP Sensor
Boost Guage
I believe that Plazmaman used to release the plenums with the AAC mounted onto the actual plenum itself but changed the design to a remote AAC block so as to not interfere with fitment of larger injectors? The block allows a certain degree of freedom when mounting the AAC (provided your lines and wires are long enough).
Ok, so started fitting it, finally. going to tap into it for the map, and booster so to reduce the length of lines. The carbon can lines can go to existing fittings on plenum.
Got a question, where the fast idle valve connects to plenum underneath in same place as stock one does, can I tee the aac remote line into the fast idle valve hose without issues? Couldnt see it harming idle.
Results!
From stock manifold to plazmaman with exact boost, went from 260kw to 270, and was last done in winter on a 20 degree day and new one 35+ and very humid. Thats at 16psi, when we went to high boost (23psi) there was not a great power gain but the power curve held hard to 7400, whereas peak prior was at 6000,, not quite back to back but a good guide.
dyno says losses in midrange. But air temp may play a large part. 20 degrees vs 35.... Its moved the power 200 revs up the range, but its got such a nice power curve now, was like a 2 stroke lol, and feels so smooth now and also makes a massive amount of intake noise when its coming on boost just under 5k.
And I just realised 1 more factor, Im running a 100cell cat, whereas wasnt with last one, so taking all into account, maybe midrange is better now?
Plus there was a fair amount of wheelspin on dyno this time. got new p-zero's and they are like jelly.
After comparing charts, my old printout had a peak of 338kw at 6k, where now it peaks at 7400 326kw, at 6k I only have 285kw.
The tractive effort has gone from 8000n to under 7000n. Still to take into account temps were way hotter, and humid, and running cat.
It feels very seamless power wise and feels to pull harder, is it possible to have gained torque even though tractive efforts gone down?
Dyno seems to say less, but I feel more..
Unless you do a back to back dyno with only the plenum changing you probably shouldn't waste any time looking at the old dyno plot. If the seat-of-pants dyno tells you it is better with the plenum, then one of two things is true. 1) It's placebo, which does happen, or 2) the car has either lost real power since the last dyno, or it is just the weather and cat causing the difference. Impossible to know unless you can back it up with some more testing.
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
