  • Replies 297
I'm with Troy, it should be a percentage of bodyweight...girls get a smaller percentage due to less testosterone and periods. Otherwise the aesthetics crew get penalised hard by the lardy lifters, who themselves usually compete in weight classes and use glossbrenner to scale. It's your rules, but you're more likely to get everyone competing with a more level playing field.
Oh and should I win one, the next challenge will be a Skyline window selfie.
Here's hoping you don't win then lol
I probably won't be competing in any of these lower body challenges because my legs are weak as piss. I'll have a dig at dips, chins, bench, shoulder press etc though when they come up.
Nice idea Tolga, good luck getting it to happen.
Some should be excluded though, yourself, Nick and Simon. No one on here will beat Ghosty at this challenge, or most challenges
I'm surprised some think that added bodyweight is a massive advantage on deadlifts
By the way, we can have a full height 20kg bar at PTC(15kg ladies bar and 2 x 2.5kg technical plates)
For just about everyone who'll partake in this from here, the "rule" of "more muscle = stronger" will fairly well apply. Of course I realise this isn't how it works! I'm just saying that for this application, it will make things a little more fair.
yeah I know the PTCs are equiped with full size light plates. but most if not "all others" are not.
Also, I'm not doing any of these challenges... lol
I'm not doing anything other than what I have planned and outlined for my states and nats attempt this year.
I'm not repeating history and risking an injury on anything.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
