Sorry to dig up an old thread but we hardly need another one...
I need to pick up a trans cooler for the M35 before the 17th of next month.
I have a stock M35 front bar with HID intercooler and was wondering if anyone could shed some insight into the dimension of the trans cooler they used.
Cheers folks :)
Bigger the better. A V8 cooler core should do the job, but it will be a tight fit behind the HDI.
I run a 30 row 50mm oil cooler, with a 10 inch thermo. The fluid runs through a thermostat to keep the trans warm in winter, and the fan only kicks in at high temps, or as required using a switch. Sounds like overkill but once you have blown a couple of boxes you will probably think it's undersized like I do. :P
Tis hopefully what i'm looking to avoid mate ;)
Cheers for the info
Cheers folks :)
I replaced my R34 GTT stock cooler with a Davies Craig 678 when I was still running an auto box, see here: http://www.sau.com.au/forums/topic/165605-auto-trans-cooler-upgrade/?p=7031106
Direct replacement, I didn't muck around with thermostats or anything. In terms of performance all I can say is that it occasionally threw the A/T light / lost fourth gear before the install but never after, at 200rwkw.
Edited by V28VX37
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
