That's your recommendation to someone who lives in Melbourne? Really?
I am assuming the stock one is still there, I have seen many skylines with the stock charcoal canister looped into the aftermarket charcoal canister.
I was suggesting to remove that fugly compliance one and only run the stock one.
That massive one in the top pic, I've seen a few R33 with that looped back into the stock one. Mine was the same, took it off and just used the stock R33 OEM one.
The stock one sits bolt next to the LHS passenger headlight, has a small u shaped hose which connects to the fuel tank. THe other 2 goes to the plenum.
I didn't even open his pictures. I just assumed it was a shot of the factory location (glancing at the thumbnails). When did they start fitting those to incoming cars? As I said, I've never seen one, and I've been under the bonnets of hundreds of Skylines over the years.
Theres 2 Vac lines going nowhere in the second photo that look the right length? usually there are labels on the top. From memory vent goes to fuel tank vent, purge goes to throttle body (or IC side of plenum) boost feed and the other one goes to a plenum boost/vac feed. Those last 2 might be wrong way round but gives you some idea anyway.
Stock charcol canister is mounted at the front on a bracket with 2 bolts holding it to the crossbrace for the radiator (Top)
Edited by 89CAL
No idea, but every so often I see one. Especially fresh ones at dealers, I believe most people just rip them out, bin them and use the stock one.
Yep, mine had one. Was a sooper shonky job too. Was the first thing I ripped out. Who needs two charcoal canisters?
So I can rip out the one in the pic ( I.e the big black fugly one with the 3 hoses)Also i can't find the OEM canister at the front that u guys are talking about, could someone post up a pic of it and how to re direct all of the hoses into the that one so I can remove this black piece of shit!
Cheers guys!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
