I changed to a 3.5 inch dump off my GT30 turbine together with 3.5 inch exhaust on my SR and made 40 more hp at 4000 rpm at the same time I swapped out a GT3071 to a 52T 3076. So I concur with DP's previous comments.
Your boost curve does seem lazy for that size turbo - 19psi at 4,000! Also you can see the power fall over up top and converges towards the lower boost setting even though more boost is being used. IMO there is an exhaust restriction post turbine housing.
Got in touch with Hyperdrive yesterday. Turns out there was some confusion about the turbo and he thought it was a T28 based turbo (e.g. GTX2867), which was why he wasn't surprised at power level. Once we clarified that it was a GTX30 with 0.82 housing he said he feels like it should be making significantly more and that he agrees the restriction is somewhere in the exhaust.
Suggested next steps were a different dump pipe, larger open mouth as per Disco's comment above, and potentially check the cat to see if any restrictions there.
I need to take the car back to get a wheel stud replaced, so will discuss plan of attack for new dump and if anything else worth changing at the same time.
Photo and or brand of cat?
If you look at the power and boost curves, it looks like once the gate opens around 3800rpm, the power curve chokes then recovers after a 1000rpm,
I would guess this is gate return pipe merging gases at a 90degree angle causing back pressure on the turbine wheel, both flows are fighting each other
If you have a proper dump, you'll probably gain 30kw's at 4000rpm, if you wind the boost up to 20psi at that point you might see 40kw's,
both gate return and dump should flow in the same direction, probably has the effect of making it more like a 2.5inch dump.
Modify your current dump . It is a good base to start with.
Cut off the existing 3 bolt flange flange and gate pipe, extend 3 bolt inch bit down to just past underneath the car, put a flange there, that gives gives you plenty of space to extend the gate pipe longer and make the merge much nicer.
It is the way it is currently because it fits in place of the factory dump pipe.
I'll see if I can find out.
For dump was thinking a 3.5" bellmouth and taper back to 3" at cat. Or maybe just get bigger cat at same time, I guess they're not that expensive in grand scheme of things.
Have a couple of photos, one of cat (not sure if anyone can ID from pic), and one showing exhaust looking from rear muffler towards mid muffler.
Have been doing some more research. Went back and had a look at Mick-o's results with the GTX3071 on 98. Comparing dyno plots; his 33 made more boost earlier, and more power everywhere. I appreciate there are differences in setups and whatnot, but seems like there's something not quite right with mine. Have overlay plot showing both which I could put up.
Also for those interested found some interesting comments from a Garrett employee on designing exhausts to get the most from turbo engines. In summary, have as little back pressure as possible, try to have smooth expansion on outlet (as opposed to sudden increase), and properly designed split system is best, but well designed bellmouth is also good.
Link here: http://www.tercelreference.com/tercel_info/turbo_exhaust_theory/turbo_exhaust_theory.html
Mark that cat looks ALOT like a stocker to me!
Wonder if its gutted or not?
At a glance thats your 1st restriction found. I know I said this before but the cross flow cooler will be hurting you. I pulled 1 out last week and they are only 65mm thick and the tank inlet and outlet are smaller than 2.5"
If restrictions like this hurt my cars performance (evo 9) im sure as shit restrictive pipework will be hurting your power and response also :)
Thanks Mick. I'd be surprised if it's the stock cat as system was installed only a couple of years ago, but could very well be a low performance one. Looking at Venom cats; it's only $220 for a 3.5" 450 series, so will probably upgrade for piece of mind if nothing else.
Regarding the intercooler, I remember you pointing out that was potentially an issue and the tuner agrees. Not sure what brand of cooler you pulled out but the Blitz SE one I have is 620 x 266 x 76 mm and piping seemed fairly large.
I'm thinking I'll try with exhaust mods and stronger actuator first, and if I don't see a decent improvement then will consider Plazmaman intercooler kit as next step.
From pics I've seen that looks like what some mobs put up as a compliance cat .
What I did was have the dump made up in 3.5 inch and used the XForce cat as a reducer . By this I mean bought the cat as a 3" generic (flangeless) and had the 3.5 flange fitted further up the inlet side cone .
I use a 200 CPI one because I didn't want the exhaust to stink , even then it did on 50/50 PULP/E85 but on straight 85 it's ok .
A .
A .
You may very well be right Disco. Exhaust was fitted when the car was pretty much stock, and before I knew much about what is needed. I imagine the current cat on there is pretty cheap.
I was thinking of getting a 3.5" cat and reducing after, either just after the cat or towards the rear muffler... If I get it changed I figure might as well be a bit conservative to remove any doubts.
What's the latest with yours anyway? Still sorting out injectors?
Hard to tell from the pictures but id check that theres no reductions in pipe size at the flanges, and no reducer in the muffler.
I've never noticed any reductions in the pipe work anywhere. Tried looking in the rear muffler yesterday and didn't notice anything suspicious, but it's hard to tell as I have twin outlets on the back so can't look straight in.
As per your link seeing as a well designed split dump is prefered, do you think you will go with my suggestion of modifying your current dump?
I'm certainly not against the idea, just that from many previous threads seems like a bellmouth dump is easier to get right. Given they'd have to patch up the hole where it currently merges, wonder if it wouldn't be easier to make from scratch anyway?
At the end of the day I'll probably go with what Hyperdrive recommends. Just waiting for this bloody replacement wheel stud to be sorted so I can book in.
Fair enough. Sounds like an option and will put that on the table for discussion too.
The other reason I've been thinking of getting the dump remade is to increase to 3.5". I realise it's probably overkill for what I have, but at least then I can rule out for sure as a possible restriction. Aaaand should be suitable if I go bigger later (e.g. GTX3071). :)
  • Like 2
  • 1 month later...
I have seen over 400wkw with the GTX3076 and I would expect it to hit hard around 4k, but it really depends on your setup. Externally gated and running ethanol will let you wind more boost in.
Personally I prefer the GTX3071 for the road, as it comes on a fair bit earlier and is capable of 350 odd on e85.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
