I have just recently bought a rb2530 complete off another forum member with unknown specs. My issue is that I have just noticed that it is an a6 block and I just really want to know the best way of finding out weather it has been a forged Rb 30 intended for sohc and they have just slapped the 25 head on it or weather it is built for the higher cr for the 2530. I sorry I'm not very good at explaining what I'm trying to achive but besides paying for it to get pulled down and getting the compression ratio checked is there another way of finding out
https://www.sau.com.au/forums/topic/419997-rb2530-issue/
Not a valid test. Thin enough fluid to be accurate will slip past the ring gaps too quickly to allow precision. When you use a burette and kero/water to cc a head, you're looking for 0.1cc accuracy. That involves using a little grease on the valve seats and so on to make sure none leaks out.
https://www.sau.com.au/forums/topic/419997-rb2530-issue/#findComment-6753714
Yuh, lipstick cam on USB is only like $20-$30. But perhaps the rather wide angle lens on them is not going to give you a reliable image that you'd swear by, unless you had a couple pf other engines with known pistons in them to compare to.
Edited by GTSBoy
https://www.sau.com.au/forums/topic/419997-rb2530-issue/#findComment-6755093
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
