when i purchased my gtr, the owners brother(owner wasnt there, everything was legit, so all good), handed my os giken twin plate(needed rebuild).
looked underneth, had tien coilovers.
trust 4inch cooler.
tuned y pipe, 3inch cat and cat back.
those were the parts i didnt know of.
did you check and see how good the ah 'mines ecu' under the back seat was, or did you just throw it out?
Tossed it ,it was not in very good condition,i think it had been there a while.
Edited by I gotta R34gtr v-spec
I bought my 34 a long time ago.. About 2 years after i bought it i went to install red bulbs behind my dash. I took the dash apart then went reaching in behind there and found some wires that seemed a bit "out of place".. So i looked up under there and followed the wires back and found a Greddy full auto turbo timer sitting in there!? hidden amongst all the other wires. All i had to do was turn it back on and mount it and boom. Free turbo timer. :D Also found a Japanese jdm game token coin like thing under my seat..
Found a 1979 20cent piece behind the roof vinyl interior of my 1981 Stanza. So I can only assume the coin was lost there while the car was on the assembly line. Still have the coin somewhere....
Jeff
  • 2 months later...
Found yellow jackets tucked down the left side of my r32's boot still in there packets! (Hopefully will fit my rb20) :)
Was looking at buying rear hicas lock bar.. Had a look underneath and already had one :)
Nismo front strut bar with Nismo stamped into it (hopefully genuine.. Not sure if those are even rare..
And last but not least about $18 worth of shrappaz!
In my 33 i Found split fires, dodgy wiring in the tail lights, really old jdm gaff tape in the doors, wierd wires all through the car, a USB with the guys birth certificate license and all his tickets, jdm coins, aus coins $14 worth, Japanese rego sticker
And the classic dried up maccas chip
4 children's nursery rhyme CDs behind the dash, played that shit all day!
Shell battery from Japan? You can't buy them here.
Shell service stickers all over and in the car from Japan.
On my gf car I found a threaded head with the spark plug sitting on top and some more threaded bolts on the thermostat housing. It was a fluke it even ran.
found tanabe GF210 on my stock springs heh i knew them orange springs were weird! also found the lock nut key from previous owner's set of nuts, which he had the tyre guys smash off, thus running only 4 nuts (until i bought a new set of nuts). what a nub. it was in the compartment which had the spare tyre jack in it, i noticed something rolling around inside.
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
