With the right offset and absolutely NO lipping or rolling of the guards whatsoever, it is absolutely possible to fit 275/40/17" Nitto NT555R's under the guards of your R33 GTS25t.
These are on a 17x8" rim and no i don't know the offset yet.
Examine:
Adrian
https://www.sau.com.au/forums/topic/42069-urban-skyline-myth-disproven/
275 means 27.5cm wide, 40 means the height is 40% of 275 = 11.0cm high. 17 is the diameter of the rims they fit.
I think the trick for the 275s must be in getting the right wheel offset, I had to roll my guards to get 265 to fit without rubbing under load
yeah, well i have this faxed bit of paper - they want measurements:
rear:
hub's face to outer gaurd distance
hub's face to inner most contact point such as spring etc distance
front:
hub face to inner lip of gaurd
hub face to closest steering/suspension
then they ask about offset - the guy said somehting about a offset of 20? so i will have 5" inside of face and 3". He reckons the tyre would almost be flush with the side?
i know **** all about this shit...bah
maybe i should scna the fax :)
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
