This gets talked about often so obviously people are interested to know if the complete RB25 inlet manifolds can be substituted from R33 25DET to R34 Neo Turbo and vice versa .
There are good reasons to attempt this ie R33 engine in R34 or the other way around . Obviously the injectors and throttlebodies/TPSs are different but if the whole assembly can be exchanged in some circumstances it could make life easier .
Anyway its been said that the Neo RB25DET has slightly smaller inlet ports and runners at the manifold flange . Most people think the Neos make better power than the R33s do even in modified form maybe the ports and manifold sizes were changed for good reasons . The way to check if the manifolds are interchangeable is to compare inlet manifold gaskets I suppose because that confirms stud holes water jackets and ports line up - or not .
I'm not sure of the wiring situation as in if the injector loom plugs are the same , I hear that the coil loom plugs are the same .
I believe the throttlebody mount on the plenums are the same so you can go either way .
The things I'm not sure about is air plumbing and the idle and cold start valves , wiring would be different here .
Anyway first things first will they bolt up to their opposite numbers head ?
A .
I have wondered this my self and found very little solid information. I have a R33 Greddy plenum here and have some inlet and exhaust manifold gaskets on order from Nissan to suit a NEO, so as long as the Greddy manifolds are matched to the R33 head correcly we should get an answer. I'll post up results once the gaskets arrive.
manifolds swap over, the electrics seem to work much the same, have run 25neo de with all its elecs off an r32 25de ecu(changing cas & coil wiring, & a few plugs), ran mint-not saying this is the preferable way but shows elecs can work together, with both motors in good condition power result for same mods should be very similar, i've got a neo to replace a s1 when it dies which i'll use the same setup (300+kw) for back to back
Inlet manifold gaskets are the same part number 14035-75T01-.
Well that would have to solve the question as to whether the ports will match up. Didn't even think to check that way, nice one.
  • 2 years later...
I was comparing R33 S2 and R34 neo today, is it normal for the Neo intake runners to be smaller diameter than the ports in the Neo head???, so therefore giving it a step/ slight mismatch?
The one with the blue on it is the R33 intake, looks like the area around the injector is different too, the R33 one is wider and more open..
Edited by AngryRB
The Neo intake manifold is narrower around the top / injector area, however on the head it is the full width of the gasket.
  • 2 years later...
I managed to get my hands on an almost bare and a complete Neo turbo inlet manifold to play with because I think its a better setup . I don't have an R33 to compare atm but I know someone that does . I want to measure the difference at the ports and where the plenum mounts on the lower section .
As we know the TBs and bolts interchange , one thing is the 33s TB gasket is steel where the 34s is paper . The 33 has a rubber gasket between the upper and lower section where the R34s is steel shim .
Something I need to find out is the ID of the coolant hose rising up from that fitting on the block behind the water pump , it connects to the Neos front bleeder section .
At a glance I think the R33 is ~ 8mm where the Neo could be 10mm . Its that hose which heads down next to the front rubber fuel hoses .
A .
The r33 throttle body has to be modified as it is different as there a small vacuum channel/hole on the r33 that a neo throttle does not have.  The area where the injector sits is larger in the r33.
Edited by AngryRB
Ah , I was going to ask the differences but thought I'd better search first . I'll have a look at my R33 soon to see what that vacuum hose goes to , I suspect the charcoal canister .
Yes I knew about the top of the manifold ports being different , the head ports are supposed to be the same in this area R33/R34 .
Cheers A .
From memory when you split the manifold the location of the runners are in a different positions to the 33 manifold.  Thats why the plazmaman manifoldd are different from  33 non neo to 34 neo.
    • Thanks for all the replies fellas. Gonna finish putting it back together and see how it handles the set up. If it starts pinging it’ll be parked.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
