Okay well tonight I hit 5x140kg on my max set after doing 8x130kg last week. Will do 140kg again next session and I hope to get 6 or 7 of them out.
My 1RM is 170kg, but I haven't attempted 1RM for a few weeks, so it should be a bit higher now that I'm approaching that figure with my working sets. I love how 1RM and working sets compliment each other on a back and forth!
My current goal is a 200kg deadlift @ 80kg, which I'll be very happy with.
Do ppp and you will be there in no time man.
200kg might not seem like anything in the powerlifting scheme of things, but it is definently a tidy 1rm for your average gym goer!
Edited by Mitcho_7
I haven't plateaued yet, so will just keep doing what I'm doing for now. Yeah man, a year ago I didn't think I'd ever lift close to what I'm doing now...stoked! Think I'll be very happy with 200.
Got out 140kg x 6 tonight...grip gave way on the 7th, just before lockout. Afterwards I couldn't open and close my hands, lol! 3 minutes later and I pulled 150kg x 3.
So...should try for 7 next week or crank the weight up and try for 150kg x 5? Be interesting to see how I do on that 1.5 x bw deadlift challenge now...might have to revisit it in a few weeks.
I sit there like a cripple with my hands all closed up for about a minute before they slowly start to open after deads.
Then another minute for the skin to kind of relax.
I reckon low reps and high weight work better for deadlifts.
I want my back and legs to be tired before my hands give way or before it becomes cardio (5 reps plus)
After doing deads in the 8-12 reps range for a while and then doing 5x5 and PPP for deads, I definently like the lower reps. Sets of 5 are probably what I like doing the most, but singles and triples aren't bad to mix it up.
Why not both?
90 x 10
110 x 10
140 x 7
155 x 4
Had no grip issues tonight, cooler weather = no sweat. Next sesh: 160 for reps.
I'm using chalk, whenever I can find it / steal it from the cross fit section at the gym. My grip is never an issue for 1RM attempts, it's the holding of the bar for extended periods of time that seems to do it.
I don't think I have the strength to lift 200 yet. I'd guess 180, maybe 185 based on my 1RM of 170 when I was doing 120 for 10 reps. I will start training the 1RM again soon, though. Took a bit of a break from it when I stretched a back muscle.
Funnily enough, the older ABC bars have better knurling than the new Ironedge bars we have :/
depends on if you are talking 1RM or reping sets and even then you can do sets of 1RM starting at 100% like below
1RM
3sets of 8 - 12 say 100kg
1 x 110kg
1x120kg
1x130kg
and so forth increasing until failure to see what your 1RM is. obviously you get tired but then you would start at say 80% of that 1RM next week
as for 7x2 i ment max weight that you could do for 7 sets would prob be 130kg instead of a 100kg for 3 sets of 8-12
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
