not warmup sets its progressive sets but it depends on what your goals are when it comes to deadlifts to whether or not you would go that way.
3x8-12 at the same weight doesnt seem progressive?
what goals would said workout be towards?
no 3x8 isnt progressive at all.....i ment if your setting 3x8 @ 100k thats where you would start off
so say if you are doing sets of 8 @ 100kg (max) then you would start at a precentage of that or even at max and do progressive increase
so start @ 1x 100kg add 2.5kg or 5kg or 10kg and continue with 1 rep. Obviously form is cruical here to increase 1RM and continue till failure so would be like this
1x100
1x110
1x120
1x130
1x135
1x140
1x142.5 (so max 1RM)
1x145 but fail
Then next week you would say start at 130kg and do it all over again
8 - 12 reps would would be heading into hypertrophy (building size) tho you would want to do 4sets
7x2 is also again different to both the above which is why it really depends on what you want to achieve
Why not both?
90 x 10
110 x 10
140 x 7
155 x 4
Had no grip issues tonight, cooler weather = no sweat. Next sesh: 160 for reps.
Argh, been sick for the last two weeks and my gym loves to close for holidays any chance it gets. Gave this a shot tonight, though:
90kg x 10
110kg x 10
140kg x 7
160kg x 3
I'd like to see 4-5 of 160kg next session, before stepping up the weight again. I probably had it in me tonight, but it would have been bad form by the end of it and, with my mate pinching a nerve last week during his deadlifts, I'm rather obsessive about maintaining form. Very happy with my progress though; can't be too far off a 200kg 1RM.
How is everyone else going with their deads? Or do we need to rename this the Birds deadlift thread?
nothing wrong with training higher rep ranges periodically... this was the first real week of programming leading up to Nationals so we are doing sets of 10
warmups to 120 then
140 x 10
140 x 10
140 x 10
then from a deficit
140 x 5
150 x 5
160 x 5
180 x 5
didn't there used to be a squat thread?
how tall are you? body shape has advantages towards different lifts somewhat.
also, how long have you been squatting/deadlifting compared to bench? the first weights anyone would be introduced to would be curls or bench at young ages...+ chins/pullups and pushups....
Edited by jangles
I have decently long legs for a 6'1 guy but leg length is a poor excuse IMO.
I have only been doing deads and squats since September, so not that long really.
Im just generally not that strong in any lifts hence why I'm doing PPP to try and change that a bit.
I try to avoid using them as an excuse, because all excuses do is stop you from achieving your goals...but long legs do serve a slight disadvantage for some lifts. Consider that deficit deads, which are done at less weight than off the floor, are based on your hips sitting higher than the normal position ala longer legs.
A long torso will also impact on an exercise like stiff legged deadlifts (or deads with high hips), due to added leverage in favour of the weight.
Tall people have more leverage to work against during squats.
However, long arms (also common on tall people) are said to be an advantage for deads and a disadvantage for bench (increased range of motion).
Either way, people have defied these generalisations, because your body, regardless of shape and size, will find ways around all this shit. You might not be genetically set up to win 1st place in a lifting comp, but there's no reason you can't get damn strong and come close, if that's your goal. Only have to look at the <6ft NBA players who punch above their height and can slam dunk, for inspiration.
  • 1 month later...
90kg x 10
110kg x 10
140kg x 7
160kg x 3
As many of you know, I've had a shoulder injury for the last two months, which, playing it safe, has prevented me from doing anything but leg exercise. I'm on the road to recovery as far as pain goes, but I think my shoulder will forever sound like a ratchet spanner.
Having not done deadlifts for 2 months has been very depressing for me and, looking at the empty bar tonight after squats made me say f**k it...let's give deads a go. And so it went:
90kg x 10
110kg x 10
140kg x 4
First two sets were pronated and third set was a mixed, with pronated injured shoulder and supinated non-injured. No pain so far; fingers crossed for the morrow.
Very surprised I was able to lift that given my absence from the exercise and straight after squats (normally did deads on a seperate day). I'd attribute it to maintaining my back with squats in the meantime. Here's hoping I can continue these cause I really missed them and my weekly progress!
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
