not warmup sets its progressive sets but it depends on what your goals are when it comes to deadlifts to whether or not you would go that way.
3x8-12 at the same weight doesnt seem progressive?
what goals would said workout be towards?
no 3x8 isnt progressive at all.....i ment if your setting 3x8 @ 100k thats where you would start off
so say if you are doing sets of 8 @ 100kg (max) then you would start at a precentage of that or even at max and do progressive increase
so start @ 1x 100kg add 2.5kg or 5kg or 10kg and continue with 1 rep. Obviously form is cruical here to increase 1RM and continue till failure so would be like this
1x100
1x110
1x120
1x130
1x135
1x140
1x142.5 (so max 1RM)
1x145 but fail
Then next week you would say start at 130kg and do it all over again
8 - 12 reps would would be heading into hypertrophy (building size) tho you would want to do 4sets
7x2 is also again different to both the above which is why it really depends on what you want to achieve
Why not both?
90 x 10
110 x 10
140 x 7
155 x 4
Had no grip issues tonight, cooler weather = no sweat. Next sesh: 160 for reps.
Argh, been sick for the last two weeks and my gym loves to close for holidays any chance it gets. Gave this a shot tonight, though:
90kg x 10
110kg x 10
140kg x 7
160kg x 3
I'd like to see 4-5 of 160kg next session, before stepping up the weight again. I probably had it in me tonight, but it would have been bad form by the end of it and, with my mate pinching a nerve last week during his deadlifts, I'm rather obsessive about maintaining form. Very happy with my progress though; can't be too far off a 200kg 1RM.
How is everyone else going with their deads? Or do we need to rename this the Birds deadlift thread?
nothing wrong with training higher rep ranges periodically... this was the first real week of programming leading up to Nationals so we are doing sets of 10
warmups to 120 then
140 x 10
140 x 10
140 x 10
then from a deficit
140 x 5
150 x 5
160 x 5
180 x 5
didn't there used to be a squat thread?
how tall are you? body shape has advantages towards different lifts somewhat.
also, how long have you been squatting/deadlifting compared to bench? the first weights anyone would be introduced to would be curls or bench at young ages...+ chins/pullups and pushups....
Edited by jangles
I have decently long legs for a 6'1 guy but leg length is a poor excuse IMO.
I have only been doing deads and squats since September, so not that long really.
Im just generally not that strong in any lifts hence why I'm doing PPP to try and change that a bit.
I try to avoid using them as an excuse, because all excuses do is stop you from achieving your goals...but long legs do serve a slight disadvantage for some lifts. Consider that deficit deads, which are done at less weight than off the floor, are based on your hips sitting higher than the normal position ala longer legs.
A long torso will also impact on an exercise like stiff legged deadlifts (or deads with high hips), due to added leverage in favour of the weight.
Tall people have more leverage to work against during squats.
However, long arms (also common on tall people) are said to be an advantage for deads and a disadvantage for bench (increased range of motion).
Either way, people have defied these generalisations, because your body, regardless of shape and size, will find ways around all this shit. You might not be genetically set up to win 1st place in a lifting comp, but there's no reason you can't get damn strong and come close, if that's your goal. Only have to look at the <6ft NBA players who punch above their height and can slam dunk, for inspiration.
  • 1 month later...
90kg x 10
110kg x 10
140kg x 7
160kg x 3
As many of you know, I've had a shoulder injury for the last two months, which, playing it safe, has prevented me from doing anything but leg exercise. I'm on the road to recovery as far as pain goes, but I think my shoulder will forever sound like a ratchet spanner.
Having not done deadlifts for 2 months has been very depressing for me and, looking at the empty bar tonight after squats made me say f**k it...let's give deads a go. And so it went:
90kg x 10
110kg x 10
140kg x 4
First two sets were pronated and third set was a mixed, with pronated injured shoulder and supinated non-injured. No pain so far; fingers crossed for the morrow.
Very surprised I was able to lift that given my absence from the exercise and straight after squats (normally did deads on a seperate day). I'd attribute it to maintaining my back with squats in the meantime. Here's hoping I can continue these cause I really missed them and my weekly progress!
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
