The goal is to train 85-95%. The reps will be low. 2-5 . This range is proven to be the most effective in strength improvement. A variety of methods adopt this in different ways.
The concensus seems to be a pure 1rm is best done very sparingly in a training shedule.
Since you don't know how to do them properly Bozodos, I'd suggest sticking to what you are doing. Once you get taught correct tecnique, then go crazy. assuming your goal is to focus on a 1rm improvement over time.
I am in this boat with you. I am not training this movement heavy till such time as I am given competent instruction. Even then interest in 1rm as any kind of training methodology beyond that. Reserved for some sort of lifting test maybe every 3 months or a comp or beer inspired show off session or all 3 at once.
The program Max has devised for our PL team has a 1RM in Week 10 of the program (PTC Method)
So our crew only hit singles once every 10 weeks, then again 2 weeks later at the meet.
In the past though, when our guys were not as strong, we did test 1RM more frequently, as it took less out of the guys.
To give you some idea, Max had never ever loaded a 270 squat, 170 bench or 260 deadlift in the gym before making those lifts at Nats. Because he had successfully completed PTC Method for 10 weeks, plus last week off completely, he was uber confident of making lifts he's never attempted. Thats good programming.
Because at PTC, no one cares what you hit in the gym
  • Like 1
90kg x 10
120kg x 10
150kg x 5
190kg x 1
Went for something different tonight. I want my volume to catch up with my 1RM training, as the gap is getting too big and I'd like to focus on improve my form on the heavier weights. So I pushed the volume weights up by 10kg. Once I get the volume up to around 170 for a few reps, I'll shoot for 200 and beyond. Was pretty happy though, as 170 used to be my 1RM not that long ago. Couldn't resist a single to finish off.
90kg x 10
130kg x 10
160kg x 4
170kg x 2
180kg x 1
I deadlifted without the aid of chalk or straps for years and then one day an Army mate I chatted with in the gym from time to time gave me a bag. Huge difference!
My current deadlift routine is usually:
6 x 100kg (warm up)
8 x 160
8 x 170
5 x 180
1-2 x 190
8 x 140
Followed up by 3 sets 10 x 60kg DB bent-over rows and 3 x machine lat pull down.
Chalk is ultimate though, should buy some and take to gym,
6 x 100kg (warm up)
8 x 160
8 x 170
5 x 180
1-2 x 190
8 x 140
good job, when you trying for 200?
I'm actually training back tonight, so might even give 200 a go. Probably go straight from my warm up to a few reps at 160 and then try 200.
I've been using the routine I detailed above (with the odd variation) for months so probably time to mix it up a bit. I tend to get comfortable at a certain level with my training and don't push myself into new territory very often.
One of the advantages of military life is the time and access to excellent quality gym's. I've been training for years and tend to just train for health and fitness rather than try to set PBs for bragging rights these days.
awesome, good luck, sounds like you have the right attitude.
Yeah cheers.
There are some strong lads in the gym on base, some of them get right into lifting bigger numbers. One of the younger guys I trained with a bit last year and earlier this year was routinely deadlifting 270-280 1RM... after pulling multiple sets at lighter weights. He did the same with bench - peaked at 180 last time I saw him. This kid was about 6'4, low 100's and all of 19yrs old!
Well I followed through with my comments earlier today about giving 200kg a shot.
I warmed up with 8 x 100kg, followed by 8 x 160, then did 2 x 200 easy enough that I decided to try 210... and I managed one without resorting to poor form. Dropped back to 170 but after 6 I was pretty much gone.
I continued on and did 3 x 8 60kg DB one arm upright rows and 3 x 8 lat pull down, but unlike normal I'm feeling noticeable more shagged. Might shift squats to Fri.
In general not sure why anyone except guys who compete don't use straps and forearms will always fail before the back does
I've always done deads last on back day as there's no energy left after them
On high rep sets my grip gives way...on low reps and singles, my back gives in first. But that's okay; both play catchup on each other. Why train around the weakness and create a dependence in equipment? I want my forearms to be strong too. You're only as strong as your weakest muscles.
As for deads last on back day, I used to do the same...but now I stick it up front as rows and pulldowns rob you of performance. They are assistance exercises to the deadlift and should be done after, so you don't fatigue support muscles early on.
Nice work there. Is that a pb for you? What do you weigh and how tall are you?
Thanks L33SH.
Thanks Birds. Yes mate it is a PB, I usually rep my way up to 190 (until tonight) not beyond.
I'm 183 / 6' and came in at 88kg on the scales tonight.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
