Cool! Should push the bar more often (or pull it), you've probably got more in you than you think. Watch how light your old weights will feel next time!
I think you are contradicting yourself a little, you are worried about weaker muscles fatiguing before your back does yet you aren't concerned the smallest muscle which plays a big part in the dead lift letting you down
Straps and suits can add a lot of weight to te bar to help increase your overall lift
There's always forearm exercises that can be done...
During repping sets you could get maybe another two reps or even more with straps as your pure focus is on moving the bar not holding on for dear life
Nice work all round guys.
Interesting that you're the same height and weight as me yet pulling a ton more, granted I have some issues I'm dealing with but it's still a top lift in my opinion so well done.
What would you "normally" weigh if you weren't doing weights? If I'm just running and no weights I drop down to a flat 80, as low as 78 as I'm a fairly light build guy normally.
Moving to a 3x8 routine from 5x5 has been "fun" lol
That's because I'm not going to injure myself if my grip lets go, but if my core doesn't stay tight during the lift, my back will take the brunt of it or I'm robbing myself of potential during lockout..
I should mention that I haven't had any grip issues since switching to mixed grip with chalk. My back is always the first to fatigue these days; it would have to be a high rep set of a very heavy (for me) weight before my grip failed. I just think it defeats the purpose of a compound movement if you use equipment to work around a group of muscles involved in that lift; bandaiding weakness rather than addressing it properly.
  • Like 1
Markos, at what level do you think a lifter should be using a belt for deadlifts, if at all? I see countless vids on YouTube of people using belts, when they are 1RMing around the same as me or less...makes me wonder if I'm not taking a precaution I should, or if I should be continuing until I find a reason to need one...
Good question. Max deadlifted 240kg before a belt, Martin 272.5kg, Zoran 280kg.
They have now obviously added belts.
Konstantinov doesnt like them for deeds, he has pulled 426kg without one but wears one on squats.
I say try one and see if you like it
Birds/Dan, cheers for the positive comments guys.
Dan, I fluctuate between 88 and 91. If I didn't train regularly I'd be low 80's. Last time I didn't train regularly was over 15yrs ago. Prior to regular weight training I did years of paddling, surfing etc. Lots of back exercises.
The issue is being weak or bad technique or both. Piss weak grip has to get stronger. Straps won't let that happen.
Good form with deads involves keeping tension in the arms and gripping the barbell with force.
Bad technique is likely a source of so called grip issues. Any slack in the arms prior to pulling the weight and cause a loss of momentum. food for thought.
Not about being weak at all, anything around 200kg and up, unless you are superman your grip will start giving up if you are doing reps
It's about being smart knowing you could lift more, more safely focusing on technique of a good lift rather than worrying about dropping the bar or putting your back out.
Have you guys actually tried straps? I only use them on deads and shrugs and on the heavier sets but knowing how much they actually benefit a lift wouldn't consider not using them. At the end of the day most guys here I see trying to get stronger on the deads and straps will aid that 100 percent
I've been known for my forearm size by friends and gym buddies but use straps for that edge, unless you want to be a pro powerlifter I think you are mad not to use them as you can add more weight to the bar and really work the back muscles harder
Even though I can only pull 190, my grip feels like it has another 50-60kg in it at the moment. Mixed with chalk shouldn't leave anyone with grip issues. There's no one who I have taught that grip to from the start, who has grip issues. I imagine the only ones who would have grip issues with only chalk and mixed grip, are those who have depended on straps for a long time.
There's simple evidence in Markos' clients...not all of them are pro powerlifters, but I doubt he would have anyone using straps on deadlifts, and his interest is in getting people as strong as they can be. Dependency is weakness. It's a fake kind of strong IMO, if you can't do the lift without the dependency.
You guys have obviously never used them because you would know the 'edge' they give. You think chalk helps? Why do you think they are banned in powerlifting? 190kg on the bar for 5 was my pb
Hey don't get me wrong I'm not telling you what to do, all I'm doing is sharing what I know works for me and all the other guys I've trained heavy with in the past
Anything to make lifting more comfortable and get your weights up why not utilize it?
Sounds like personal preference. If you're not training for comps I say do whatever the hell you want. I wear gloves because I prefer it, you guys have mentioned it will be an issue for me, the apparent issues are not as important to me as the benefit I get, so I wear them.
I don't see straps being any different.
Action Dan they must think they are pro powerlifters with their strict rules
I was into bodybuilding not powerlifting so I used them to have hands like hooks which helps take the weight the back muscles better
Sometimes I used them on lat pull downs when doing around 300lbs
I see why they say don't use them, as the idea is to try and make the whole body strong and you're kind of working around a limitation.
But realistically, for anyone not competing it makes 2 tenths of f**k all difference so do whatever you like.
I'm guilty of this as well though, we all get caught up on specifics of things that probably don't matter that much to non competitive guys like us.
Edited by ActionDan
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
