Yep and all the units have CAN controllers to report if there working or not, and centralized everything in the AV Unit. Unlike the non bose, base units.
Check out the US manual and you can see the sort of complexity your dealing with...
http://www.nicoclub.com/FSM/G37/Coupe/2009/AV.pdf
Here's a fun thing to look at. Turn the car on, turn your audio off, press and hold settings button (bottom left, big button) then spin the volume control. Then practice your Japanese, i'll try and get my friend to translate it and put some screen dumps up. Definitely useful if you start splicing stuff into the car and you want to make sure it still works.
It will bring up the diagnostic screen and show you whats connected. I pulled the TV unit out the other day to have a look inside to see what chips were on it, some TV tuner micro chip boards follow a standard plug and play design for the tuner. No luck, recognized half the chips on the mother board, but need to know the pinouts are on the connection, If i had the Japanese manual for the actual car then i could get somewhere,
But does show up clear as day on the diagnostic screen that it is not plugged and simplifies the TV/AUX button so it just goes to AUX and you don't have useless fuzzy TV screen stuff. And there is tons of room in the boot back there to fit something in there...
I've seen lots of posts in the states with guys porting CarPC's in there and using Centrafuse, splicing into the unit either with the reverse cam or GVIF boards and then hooking into the OEM touch screen or adding an overlay over the top.
But yes definitely in the $3k territory plus fitting.
mike lo , are you in vic at all? (and if you are do you deal with me.)
the above post is pretty much correct. xanavi (hitachi) are very closed about who has access to FSMs for those units. I have tried several times without success to get info on that unit. at least with the clarion (non nav) I can get info .
Hey Chris,
Interested to know what you think would happen if someone managed to capture a HDD image from a 2009+ NAVI optioned local Murano Z51 Ti, Navara STX-550, 370Z or Pathfinder Ti R51? Do you think the image would even boot?
I assume the buttons would still present a fairly major challenge since they all appear to be in different places.
  • 1 month later...
Had a chance to buy this the other day
Nissan Infiniti G37 CONT ASSY-IT MASTER HDD car Navigation 25915 1MA4B 1JG0A 1JA0A US version
The price was less than $400 delivered.
Would it have been any use to us?
Is the 2010 V36 very different to the 2008?
I found a 2010 coupe on Carsales with Aus GPS that looks to have come with bose/jap nav.
http://www.carsales.com.au/dealer/details/Nissan-Skyline-2010/AGC-AD-14419450/?Cr=17&sdmvc=1
146970798.jpg?height=700&aspect=FitWithi
Not one of mine. I have a garmin version sitting here that I am going to put in production though . I know whatbthTvis and the are prone to failing.
    • Kinkstah, no, coilovers aren't illegal, especially as a bolt straight in. The illegal part will be if they're altering suspension geometry beyond factory limits, or the ride height is not legal.   Sounds like the blue slipper just didn't want to deal with any later possibility of mods appearing on the car.
    • The problem has always been that coilovers are able to be adjusted, almost at any time, to be too low. Most people who ever get/got defected for/with coilovers were actually afoul of the minimum ride height rule. So the interpretation by cops/inspectors was always that it is pointless to allow numpty to raise his coilovers and get the car inspected/cleared, then just drop them back down again as soon as they get around the corner from the inspection station.  This led to the interpretation that they were illegal unless rendered such that they can't be adjusted (ie, collars welded to the body, that sort of thing). That may or may not have ever actually been the official line, but I'm pretty sure it's not considered to be a solution these days. Coilovers themselves fall under clause 3.2 b of that manual, because they are an "installation of a variable ride height system" and they don't fit the exclusions in that clause (which point to air springs and other pneumatic adjusters). So, as per previous statements, they require engineering cert to be legal on the road. Once you have such cert, provided you do not adjust them outside the height range covered by the cert, you are OK. Without, you have an unroadworthy vehicle.
    • Here E10 is the cheapest fuel. And general advice is to not use it unless you hate your car. From what I remember it clogs up stuff in the fuel system or injectors?  With US/Canada being E10 across the board, does that mean that all fuel there is terrible?
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW ) Edit: I checked. They aren't. https://www.nsw.gov.au/sites/default/files/2021-02/RMS-infosheet-light-vehicle-modifications-manual-suspension-and-ride-height.pdf
