Hi, I am considering the v37 2009 model and understand from reading here that you can't get the navi working or maps for it here. I was looking at the Aus infiniti coupe and it looks to be visually the same navi unit. Has anyone checked the part number and cost of this unit so that it could just be retrofitted to the import and has anyone tried inserting the Aus spec dvd into the import to see if it will read it? Just curious if this is an option and have not seen it discussed.
I had someone in Sydney ring me in this today. It's NOT a direct swap.
You need to change:
Buttons
Controller for butttons,
screen
Navi control unit
Main radio button panel
and roughly $10k in cash.
Max,
tis fine . most people CBF'd reading and prefer to be spoon fed :-)l
  • 1 month later...
All I want is to disable the VSS wires on the foot ("hand") brake from disabling the AUX screen. My 2007 V36 Sedan has the AUX video and Audio inputs in the centre console, so using video out on a phone should be enough for us Navi owners ?
I have seen tutorials of the US car having the handbrake video disabled, but the wires are apparently diferent colours ?
  • 4 weeks later...
Im thinking of getting a v36 non navi for my next car. I am just wanting to know if the stereo is able to connect to an iPod properly and listen to fm radio via an expander and have it being usable? Thanks for any advice
The FM expander works regardless.
What do you mean when you say "work properly" in reference to your iPod? Are you talking about just line level/aux audio input or having full control of your iPod from the OEM stereo controls?
  • 2 months later...
  • 3 weeks later...
A quick note to those finding this in google.
Calling me , getting me to look at the car and then requesting all the part numbers to do the nav swap on a 2011 v36 because you think you can get the parts your self is outright rude. I am not a charity and I will not think twice about calling you out on it.
    • Kinkstah, no, coilovers aren't illegal, especially as a bolt straight in. The illegal part will be if they're altering suspension geometry beyond factory limits, or the ride height is not legal.   Sounds like the blue slipper just didn't want to deal with any later possibility of mods appearing on the car.
    • The problem has always been that coilovers are able to be adjusted, almost at any time, to be too low. Most people who ever get/got defected for/with coilovers were actually afoul of the minimum ride height rule. So the interpretation by cops/inspectors was always that it is pointless to allow numpty to raise his coilovers and get the car inspected/cleared, then just drop them back down again as soon as they get around the corner from the inspection station.  This led to the interpretation that they were illegal unless rendered such that they can't be adjusted (ie, collars welded to the body, that sort of thing). That may or may not have ever actually been the official line, but I'm pretty sure it's not considered to be a solution these days. Coilovers themselves fall under clause 3.2 b of that manual, because they are an "installation of a variable ride height system" and they don't fit the exclusions in that clause (which point to air springs and other pneumatic adjusters). So, as per previous statements, they require engineering cert to be legal on the road. Once you have such cert, provided you do not adjust them outside the height range covered by the cert, you are OK. Without, you have an unroadworthy vehicle.
    • Here E10 is the cheapest fuel. And general advice is to not use it unless you hate your car. From what I remember it clogs up stuff in the fuel system or injectors?  With US/Canada being E10 across the board, does that mean that all fuel there is terrible?
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW ) Edit: I checked. They aren't. https://www.nsw.gov.au/sites/default/files/2021-02/RMS-infosheet-light-vehicle-modifications-manual-suspension-and-ride-height.pdf
