Hey guys!
Finally got my car approx 2 weeks ago and already popping with questions! Got my car back from the shop today (major service) and apparently the car is only going three quarters as fast as it should be! I tried to research the problem but have no flippin' idea what I'm looking for!
Apparently when you put the foot down the turbo.. cuts in and out? like it's there, then not there, then there again. I didn't notice this until I put my foot down to understand what the mechanic was on about. He said it may be electrical(went into jargon I couldn't understand lol)? I was hoping for some input/thoughts to give the mechanic the next time I see him as they charge lots by the hour lol
Only changes done (related to problem) is the boost restricter being removed. so instead of 7psi, it's 14psi. But I don't see the boost gauge use all 14 pounds. Apparently this isn't the problem, I don't know. Any ideas would be fantastic!
Cheers in advance guys!
https://www.sau.com.au/forums/topic/422021-r33-gtr-turbo-cutting-out/
Does it have a k & n filter that use oil, if over oiled it will suck through the filter onto the maf and affect your reading, specially on boost. Check your coil packs for cracks and for fouled plugs. sense you just got it you should hit up the dyno or road test and check your AFR just for piece of mind. List any mods as this will help us help u
Did they change your spark plugs on the major service? My guess is its missing and if they installed new plugs they might just need to be regapped. Is this happening all the way through the rev range or just on boost when applying WOT?
got stock ecu? try resetting it
also search for dry solder on afm, its not difficult to check
Yeah it is stock. I'll look into it thanks!
Yeah plugs were changed during the service. This "misfiring", "cutting" is only happening when I put my foot down.
google missfire and see if a more professional description matches with what your experiencing
I've had a squizz through and watched a few vids but they sound more serious than what mine is, I have no leaks, car idles no problem.
As a free bump! my GTS-T is doing the same thing. Once you get over 7psi, even 8psi! it feels like its hitting a rev limiter/ tapping the accelerator on and off. yet if i leave the car on 7psi i can flog the crap outta her and she's happy.
Op. Running nore boost will cause you to run out of spark aka missfiring. Its got shitall to do with idle unless a coil pack dies.
Second dude. Youre either hitting too much boost which the ecu is cutting you off or you also are running out of spark.
Change spark gaps up boost.
Yeah had some ideas, apparently my car is tuned to handle unleaded 95 when I've been putting in premium 98. Doubt that'll have anything to do with it. Checked the air flow sensors and they seem fine. Still got the cutting in and out happening though. Will check out other probs tomorrow!
yeah I bought some split fire coilpacks. hope they come in before the easter break. would like to hit more than 0.7(unsure on conversion to psi. its reading I get) bar before my car throws a hissifit. my camry runs better at the moment.
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
