So ghey. Needs more 1JZ foo!
See you Sundy big guy. :wub:
How about an sr20 cortina ;)
But yes definitely keen for Sunday, I should fix this exhaust leak but don't want up fark anything up before then.
i fitted my front camber arms yesterday and wound a bit of neg into it (moreso for looks lol)
Also had it out for qr happy laps today, and it went well for being what is essentially a stock motor. My battery clamp broke so I couldn't corner to hard also cooked my pissy Natro brakes and my rears tires are now catus :thumbsup:
*note shit house front fitment as my 30mm bolt ons rub to much, so I took them off and will purchase a set of 20mm
The car looked like it went well man! Whats next on the menu?
Yer I was really happy with it, went really well for a stock motor. Next on menu in no particular order:
New tires
New brake pads
New front wheel studs and spacers
TO FIX THIS BLOODY GEARBOX!
New tires
New brake pads
stoopid question.... your gbox prob and tacho probs.... they couldnt be related could they? speed sensor issues etc?
just a thought honky!
His speed and tacho probs are just that the signal going to the gauges is wrong.
The correct signal is getting to the ECU which is doing shifts. The ECU has identified a fault with Soln A in the box, and hence locked it out.
didnt know it was confirmed as solenoidssss. thought he had checked em.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
