http://m.youtube.com/#/watch?feature=youtube_gdata_player&v=yEwEv-2cjxk&desktop_uri=%2Fwatch%3Fv%3DyEwEv-2cjxk%26feature%3Dyoutube_gdata_player
Give you an idea of how badly I couldn't get it to hook up, turned tire to almost the 330ft mark on this run *shakes head* :dry:
Can't wait for some sticky rubber :)
Does it have an LSD?
Just a factory one ATM, was talking to Dan about 1.5 ways the other week. In saying that its still turning both wheels even so the old girl must not be to worn yet
yea mang. your gonna get some launch now boy! remember. soften up thos farking coils. and get mother f**king pineapples to twist your diff!
Yep, drag day tomorow will be on street tires again :(
Went 13.71 at 104, I think on the day as the track and car is that's about as fast as I could of went. There might be a bit more in it but just not on this set up.
Probley won't go back untill the new cam and stuff goes in :)
Not a bad time mate. :)
Thanks mate, I'm a little disappointed. I really thought it had a low 13 in it with this set up but apparently not.
In saying that I chopped a 2011 maloo ute by alot of car lengths aswell as an evo and a few other skylines on the day (also lost to an Audi r8 by 0.09 of a second across the line lol). I think alot of people think they're cars are faster "time wise" then what they are, I duno it cut a 13.7 and smashed alot if cars so what does that tell you.
Now.... Cam time :thumbsup:
.... 13.7 for a relatively stock ls1 in a reasonably heavy car is pretty good going. Your 33 is about the same weight as a commo with no interior or fat chicks. Most people have no idea how fast a flat 13 sec 1/4 really is.
N20 time... :yes:
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
    • Ok so i will NEED to have this sensor anyway even with Nistune (or standalone ECU) https://justjap.com/products/genuine-nissan-boost-pressure-sensor-evap-control-system-fits-nissan-r34-skyline-c34-nm35-stagea-pnt30-x-trail-rb25det-vq25det-sr20vet?currency=AUD&srsltid=AfmBOoqfxX48bW9bEwH62orcNhtBfp7ekAL0C9Ca89ySFGUiBzXfXeze Is this the correct one? And this is only thing i need? No other "things" connected to the sensor or something? I do have the wiring.
