Higher wattage bulbs on stock wiring...........bad idea.
First step always is to fit relays, thus removing the high amperage load on the high/low dipper switch and at the same time giving full voltage to the lights.
You'll immediately notice an improvement by getting decent power to your existing bulbs and with relays fitted you can then try higher wattage bulbs without the worry of melted wiring or burnt contacts on the dipper switch.
If you want more illumination, try HID's on your low beams. They cut off nicely with the projectors but are illegal and you could get a defect.
Go for 4300k max which produce the whitest light and it's not quite so obvious you have HID's.
Fit a diode to trigger low to stay on with high for better highway night driving.
Job done.
R32 projectors are absolute shithouse. The projectors in my R31 are 3x better. Don't bother putting a HID kit in, you will be disappointed, plus the glare from standard projectors is disgraceful.
Step 1. Put relays in, unless you like burning out the headlight switch or your whole car.
Step 2. http://www.skylinesaustralia.com/forums/topic/93963-xenon-hid-lights-conversion-for-r32/
Massive, massive difference. I wouldn't bother with anything else. I've tried different setups, HID kits, higher wattage bulbs (H3 of course, don't bother with blue bulbs even if they're 100W). I wish I went straight to HID retrofit, would have saved $$$$.
As mentioned, 4300K is the colour you want (HID). 5000K for fully sickness, anything higher is pure wank and you will see less.
ok got a set of povo lights and fitted tonight, definately brighter with plain h4 bulbs, the reflector is like twice the size of the projector.
just gotta work out the wiring for the fog light now, it has a grey and white loom in the engine loom behind it.
the fog can take the same bulb as the high beam in the projector, except it doesn't have anywhere to ground itself to like it does in the projector housing.
ok, another update.
hard to compare against the stock projectors with generic bulbs, but this is my take on it.
the brick headlights are brighter with narva plus 120 bulbs (a given), but i think it is also nice having the fog lights (with generic 55w h3c bulbs) in which I can switch on at the same time on a dark road.
haven't measured the voltage drop yet, but that'll be my next step, to run them off relays.
at some point i might get some plus 120 h1's and fit the projectors back to compare, but then i'd lose the fog lights.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
