Just keep chipping away doing lots of squat volume around 80-85% 1RM and add weight/sets/reps when you hit targets like 5x5 etc so you're continually increasing the stress, this way you maintain form and don't injure yourself, and you're using heavy enough weight to stimulate growth. You're a novice squatter going by the weights listed so it's just going to take some time to build the strength. If in doubt squat, then squat some more :)
Edited by GHOSTrun
https://www.sau.com.au/forums/topic/422559-squattin/page/4/#findComment-6825712
I do "good morning" the weight up when I am struggling in the hole sometimes. Is this a bad thing? Indicative that I should be further back on my heels?
it's very common, especially with 'high bar' squatters... not a terrible thing as long as your not bending excessively... make sure your taking a big breath before each rep and hold it until you finish the rep... this can help brace your core... belts help as well but don't think you need one yet
yep if you let the weight drift forward onto your toes you will find yourself getting bent over
you can also do some good mornings as an assistance exercise
https://www.sau.com.au/forums/topic/422559-squattin/page/4/#findComment-6825741
hips are generally stronger so they tend to rise first when close to your max and so good morings occur.
Just so you know, I've hurt my back due to this in the past.
Assume your current max is 105 and go back to doing 70 - 85% for reps for a while.
That is my opinion/suggestion
Edited by TTT
https://www.sau.com.au/forums/topic/422559-squattin/page/4/#findComment-6825829
60kg x 10
75kg x 10
90kg x 8
100kg x 3
105kg x 1 (died on second rep; thank you safety bars)
I think the leg press is helping a fair bit with squat strength, along with progressively stepping up the weight on squats. I'm tryIng my best not to lose form as I step up the weight...it is still very ATG...however...I do "good morning" the weight up when I am struggling in the hole sometimes. Is this a bad thing? Indicative that I should be further back on my heels?
Damn, Im in a very similar position to you. The numbers are almost identical! Out of curiosity what weight are you doing on the leg press? Its probably irrelevant for squats, but would be good to know. After the squats, I am up to 320kg for 3 reps (300kg for 5). This has increased a lot in the last month but the squat hasn't at all, which is very frustrating!!!!
On the squats, as soon as I go for 110kg, when i try to go low, I start to fall forward!!! Shitting me big time. I have to get some decent advice on how to squat properly. Mind you as per above advice, I'm doing for 5x5's now starting at 60kg and going from there.
https://www.sau.com.au/forums/topic/422559-squattin/page/4/#findComment-6825992
Leg press weights, or any machine, is irrelevant, as they are designed and made differently
I used a Hack Squat at Golds in Venice Beach with 3 plates aside
The one I was using back home at the time allowed for a 25lb plate per side
Thats a huge difference.....150lbs to 25lbs per side
Can only compare on the same machine
https://www.sau.com.au/forums/topic/422559-squattin/page/4/#findComment-6826890
I witnessed a bloke in my biomechanics class at uni pump out 25x100kg atg squats like it was nothing today. I train at home so it was crazy to see someone lifting that in front of me, takes it to a whole other level.
I would probably be in a permanent state of dropped jaw if I were to go to Markos' ptc gym!
https://www.sau.com.au/forums/topic/422559-squattin/page/4/#findComment-6826963
As work has settled down, and i'm getting my car back, I feel it is time to really focus on improving my squats once more.
I may have to post up a video to gain some insight on why I feel like my hips are hinging forwards if I try to squat deep.
https://www.sau.com.au/forums/topic/422559-squattin/page/4/#findComment-6832609
100kg x 25 is good in any gym, thats great work Mitch
Our guys are into their first week of 5's
Martin got 200kg x 5, Max did 205kg x 5, Dan did 205kg x 5, Zoran did 205kg x 5,Emad 210kg x 5, Spiros 215kg x 5, Jack 240kg x 5, all for 3 sets
Max has 220kg x 5 this Saturday
https://www.sau.com.au/forums/topic/422559-squattin/page/4/#findComment-6834669
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
