Just keep chipping away doing lots of squat volume around 80-85% 1RM and add weight/sets/reps when you hit targets like 5x5 etc so you're continually increasing the stress, this way you maintain form and don't injure yourself, and you're using heavy enough weight to stimulate growth. You're a novice squatter going by the weights listed so it's just going to take some time to build the strength. If in doubt squat, then squat some more :)
Edited by GHOSTrun
https://www.sau.com.au/forums/topic/422559-squattin/page/4/#findComment-6825712
I do "good morning" the weight up when I am struggling in the hole sometimes. Is this a bad thing? Indicative that I should be further back on my heels?
it's very common, especially with 'high bar' squatters... not a terrible thing as long as your not bending excessively... make sure your taking a big breath before each rep and hold it until you finish the rep... this can help brace your core... belts help as well but don't think you need one yet
yep if you let the weight drift forward onto your toes you will find yourself getting bent over
you can also do some good mornings as an assistance exercise
https://www.sau.com.au/forums/topic/422559-squattin/page/4/#findComment-6825741
hips are generally stronger so they tend to rise first when close to your max and so good morings occur.
Just so you know, I've hurt my back due to this in the past.
Assume your current max is 105 and go back to doing 70 - 85% for reps for a while.
That is my opinion/suggestion
Edited by TTT
https://www.sau.com.au/forums/topic/422559-squattin/page/4/#findComment-6825829
60kg x 10
75kg x 10
90kg x 8
100kg x 3
105kg x 1 (died on second rep; thank you safety bars)
I think the leg press is helping a fair bit with squat strength, along with progressively stepping up the weight on squats. I'm tryIng my best not to lose form as I step up the weight...it is still very ATG...however...I do "good morning" the weight up when I am struggling in the hole sometimes. Is this a bad thing? Indicative that I should be further back on my heels?
Damn, Im in a very similar position to you. The numbers are almost identical! Out of curiosity what weight are you doing on the leg press? Its probably irrelevant for squats, but would be good to know. After the squats, I am up to 320kg for 3 reps (300kg for 5). This has increased a lot in the last month but the squat hasn't at all, which is very frustrating!!!!
On the squats, as soon as I go for 110kg, when i try to go low, I start to fall forward!!! Shitting me big time. I have to get some decent advice on how to squat properly. Mind you as per above advice, I'm doing for 5x5's now starting at 60kg and going from there.
https://www.sau.com.au/forums/topic/422559-squattin/page/4/#findComment-6825992
Leg press weights, or any machine, is irrelevant, as they are designed and made differently
I used a Hack Squat at Golds in Venice Beach with 3 plates aside
The one I was using back home at the time allowed for a 25lb plate per side
Thats a huge difference.....150lbs to 25lbs per side
Can only compare on the same machine
https://www.sau.com.au/forums/topic/422559-squattin/page/4/#findComment-6826890
I witnessed a bloke in my biomechanics class at uni pump out 25x100kg atg squats like it was nothing today. I train at home so it was crazy to see someone lifting that in front of me, takes it to a whole other level.
I would probably be in a permanent state of dropped jaw if I were to go to Markos' ptc gym!
https://www.sau.com.au/forums/topic/422559-squattin/page/4/#findComment-6826963
As work has settled down, and i'm getting my car back, I feel it is time to really focus on improving my squats once more.
I may have to post up a video to gain some insight on why I feel like my hips are hinging forwards if I try to squat deep.
https://www.sau.com.au/forums/topic/422559-squattin/page/4/#findComment-6832609
100kg x 25 is good in any gym, thats great work Mitch
Our guys are into their first week of 5's
Martin got 200kg x 5, Max did 205kg x 5, Dan did 205kg x 5, Zoran did 205kg x 5,Emad 210kg x 5, Spiros 215kg x 5, Jack 240kg x 5, all for 3 sets
Max has 220kg x 5 this Saturday
https://www.sau.com.au/forums/topic/422559-squattin/page/4/#findComment-6834669
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
