Have you tried stretching or using a really light weight at the end of your sets to try and push lower? I've always had good hip flexibility despite my long legs. My hamstrings are pretty poor though.
https://www.sau.com.au/forums/topic/422559-squattin/page/6/#findComment-6842246
Next session go
bar x 10
40 x 8
60 x 5
80 x 3
100 x 1
then go 115 and 120
stop doing a million reps before your 1rms
Why you gotta hate on my gazillion reps? I love the volume stuff.
I know that's the best thing to do to increase 1RM, i.e. cut down on my volume...so I'll probably turn to it when I start plateauing bad with the current setup. But for now I enjoy sticking the 1RM after a heap of working sets. Because Birds
https://www.sau.com.au/forums/topic/422559-squattin/page/6/#findComment-6842252
Argh
http://answers.yahoo.com/question/index?qid=20100122075103AABalxd
Came across that when tryin to find that bad technique thing where the ass "rolls" or "dips" during a squat. What's it called again?
https://www.sau.com.au/forums/topic/422559-squattin/page/6/#findComment-6842501
Cheers
Yeah I gave up reading after the first two comments. The chosen answer supposedly a trainer for an international weightlifting association? Err...
There's misinformation and then there's MISSINGinformation!
https://www.sau.com.au/forums/topic/422559-squattin/page/6/#findComment-6842620
do your volume after you go heavy, not before... just do enough to warm up, hit a pb, then do a heap of volume work
^^ This.
You're not going to find your 1rm doing it your way.
You're only going to find your exhausted 1rm.
Do it like I said, then once you fail a 1rm, have a 5 minute rest, then load up your volume sets and go for broke back mountain
  • Like 1
https://www.sau.com.au/forums/topic/422559-squattin/page/6/#findComment-6842960
60kg x 10
75kg x 10
90kg x 8
100kg x 3
110kg x 1
Got a bit worried on the 90, being down a rep from Friday. Felt good about the 100 x 3 though, so I shot for 110kg and there it is. Will try and get 2 of them next time or shoot for 115.
60kg x 10
75kg x 10
90kg x 8
100kg x 3 (died half way up on 4th rep)
115kg x 0 (died half way up)
Didn't make the 115 tonight; back just didn't want to work with me after the fail on the 100s. Next time maybe!
https://www.sau.com.au/forums/topic/422559-squattin/page/6/#findComment-6846202
  • 1 month later...
60kg x 10
75kg x 10
90kg x 8
60kg x 10
80kg x 10
100kg x 4 (fail on 5th rep)
110kg x 0
90kg x 3
Was sick with a cold this week, debating whether to come. No one ever got anywhere by being home with a cold, so here I am.
Feel like I'm leaning forward too far on the heavier weights and the motion is turning into a bit of a good morning, as my back is giving way before my legs are. Seems to be consequential of trying to squat all the way to my ankles in oly stance; need to sit back on my heels more and keep the hips from coming up before my back. Hoping to post better results next sesh.
https://www.sau.com.au/forums/topic/422559-squattin/page/6/#findComment-6898825
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
    • Probably. I take it that they are also mentioned to be for R34 Skyline? For example.... RDA has that part as RDA7957. I have the dimpled and slotted version of that on my car https://www.ebay.com.au/itm/285518478694?srsltid=AfmBOopKxMuAFpsxZJdB1cam4D5RAj1f9yJyOttPZLAwXVNCOiwlhrIy This is DBA's top one piece equivalent https://www.ebay.com.au/itm/364246686631?srsltid=AfmBOorbb0XHQgqTvZLgQPhg70nqJtGvdojKnugum3O2LFSr2h-obp8D
