Ah big fella how nice it must be to have your own little fan club.
I might have to give you some pointers on the old classic reach-around so you can service all your bitches properly.
since the fuel tank and shit fuel thing i have bodged up a new filling method to be extra filtered
basically used a walbro gtr setup, added a ciggy lighter connect + fuel filter + toggle switch = new way to filter fuel before it goes into the car
triple back up now so the ar has 4 filters have a crack at the fuel before it hits the engine
ps fyou blaxland e85
takes 4 minutes to empty a 20 litre tank so me thinks walbros 400 litre a hour ratting is bs
you old men! it takes like 30 seconds to hold the thing and fill it
lol super cheap can takes about 3 minutes as they are shit
It's not the point.
You can be drinking a beer while it's filling up.
dam straight
main issue is the two children
have other things to do between sessions
got a few good sessions in the old girl today
1:03 flat which is a .7 improvement
i think the old f**ker has a low 1:02 in it no dramas but once again ran into some drama so didnt get many runs in (
missfire when she got hot ( so after 6 laps))
then the power steering lunched itself and gizzed on the track and the day was over
had a better day that this poor fella though
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
