9th out of 86 cars
brakes epic
handcock rubber heaps better than r888's
Great work Pete! Awesome result, especially considering your success ballast (you can successfully find beer and pizza better than most).
Seriously though, it's an awesome effort in a home built car done on a shoestring budget. Tight Wad Racing (TWR) FTMFW!
...Ben
  • Like 1
  • 3 weeks later...
Nulon Nats done and dusted
turns out my love for 4wheel smoke shows from the start line has taken it toll on the little os twin plate
Buladelah is a epic fun little track
even better when run one is also the recce run
run two and the clutch gave up was flaring through all gears
Duncan got it running and i babied it up the hill one more time
then game over. had to start it in gear to get it on the trailer
still managed 10th outright on a slipping clutch run
this may be the one that got away as the car with a working clutch would have been in the top 3 sleasy as
anyway here is the vid... listen to that f**ker slip in 3rd and 4th
there were some epic crashes
one evo rolled 3 times that f**ker was lucky and f6 tanked a embankment so hard it kinked the roof
cage time for me
next weekend off to ec see if i can run a low 40
os tripple will be in tomorrow so that should allow me to break things other than the clutch
  • Like 2
just some other pics
and who says 310-350rwkw + front and rear LSD's + uphill hill climb launches+ soft 295 semis are good for a twin plate
i would say its done about 100 launches in its 5k of driving and lots of clutch kicking mid corner when off boost
was not blue when i stuck it in
lol
i think i might lay of the clutch kicks mid corner to save a few dollars lol
almost lifting a tyre... f**k yea
will have the os tripple in buy tomorrow ready for more abuse
track day sunday
f**k yea car is going to die
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
