9th out of 86 cars
brakes epic
handcock rubber heaps better than r888's
Great work Pete! Awesome result, especially considering your success ballast (you can successfully find beer and pizza better than most).
Seriously though, it's an awesome effort in a home built car done on a shoestring budget. Tight Wad Racing (TWR) FTMFW!
...Ben
  • Like 1
  • 3 weeks later...
Nulon Nats done and dusted
turns out my love for 4wheel smoke shows from the start line has taken it toll on the little os twin plate
Buladelah is a epic fun little track
even better when run one is also the recce run
run two and the clutch gave up was flaring through all gears
Duncan got it running and i babied it up the hill one more time
then game over. had to start it in gear to get it on the trailer
still managed 10th outright on a slipping clutch run
this may be the one that got away as the car with a working clutch would have been in the top 3 sleasy as
anyway here is the vid... listen to that f**ker slip in 3rd and 4th
there were some epic crashes
one evo rolled 3 times that f**ker was lucky and f6 tanked a embankment so hard it kinked the roof
cage time for me
next weekend off to ec see if i can run a low 40
os tripple will be in tomorrow so that should allow me to break things other than the clutch
  • Like 2
just some other pics
and who says 310-350rwkw + front and rear LSD's + uphill hill climb launches+ soft 295 semis are good for a twin plate
i would say its done about 100 launches in its 5k of driving and lots of clutch kicking mid corner when off boost
was not blue when i stuck it in
lol
i think i might lay of the clutch kicks mid corner to save a few dollars lol
almost lifting a tyre... f**k yea
will have the os tripple in buy tomorrow ready for more abuse
track day sunday
f**k yea car is going to die
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
    • Ahh. Well the block damage is a problem, you really need to run a tap or thread chaser through it to see if the threads can be saved, but any chips are likely to be bottom end bound which is bad. Earls seem to have what you need if you want to stick with mounting direct on the block: https://rceperformance.com.au/parts/earls-straight-adapter-1-8-npt-male-to-1-8-bspt-female.html, but as I said above I'd recommend remote mounting the sender
    • I'm not quite understanding or I'm missing steps here, (I appreciate people are trying to inform my brain but I am of the dumb, especially today) - All I want to do is mount the male BSPT of the OEM sender into the system somewhere without it snapping the adapter via vibration. The Nissan sender has a male 1/8 BSPT output. The block has a (very destroyed) 1/8 NPT input. I'm not really sure how a lathe assists with that, and also don't know anybody with a lathe, nor specifically what I would want to buy. I'm not really sure how adding additional adapters creates a better, more leak proof resilient seal here.
