Can anyone give me an idea what clutches are out there that are strong enough to take 650hp but still be drivable around the street without lurching at the intersections. My gtr has a insane twin plate in it that the second u release the pedal the tiniest, the clutch fully engadges making town driving very uncomfortable. Ive been told the Nismo super coppermix clutch is meant to be really good (link below) but wondered if anyne has one an could tell me what its like, or any other suggestions of a clutch, I drive the car once a week if that. so having that insane twin set up, whatever it is, is too much.
Any help greatly appreciated :-)
http://www.nismo.co.jp/en/products/competition/clutch/sctwin.html
https://www.sau.com.au/forums/topic/423011-best-clutch-for-high-hp/
Its gotta be good to be Nismo :-) My car beig sent for new dyno after they've put a better fuel set up in the boot, an Im swapping ecu to hks fcon vpro, so gonna get the clutch done then, cant wait to see the results of it all
you can use a single plate clutch for over 1000hp applications, but wont be very streetable..
i talked to the gearbox engineer at rapisarda racing and he told me to go for a nice single plate clutch for my track car.
but any twin plate will be abit tougher to drive,but the nismo twin is easy as hell to drive even around town. was in a 260kw r33 with one in that and was heaps easy.
I used to have an Exedy twin and it was a pig in traffic and the pedal was a lot heavier than standard. I now use an ATS triple carbon clutch whick feels like a standard clutch to drive. They're also a lot lighter which makes it easier on gearbox synchros between gear changes! The only downside is that they're are fairly expensive, but if you can afford to run a 650hp RB then I guess you can afford one of these. Highly recommended!
http://www.nengun.com/ats/carbon-clutch
Edited by Never Enough
Thanks for the help guy :no:
Im happy to spend to money to get the best clutch for the job, what I want to be sure of is, it's not that the pedal is too hard to press, mine feels only a lil harder than factory, but the issue I have with the clutch is it fully engadges as soon as u release pedal the tiniest, so its great for launching, but not great at traffic lights, whih the car spends more time around town than a track, So with the ATS triple carbon clutch is it streetable in that sence, The Nismo clutch read up says its good for round town yet still tough enough to take the power.
The ATS clutch slips well but once it warms up it tends to grip harder so higher revs are required from a standstill start. If you search there's other members that have posted similar questions to yours. This should help you make your choice.
I run a single plate that will take 650hp and is daily driven, very nice clutch.... A bit bitey on occasion but much better than a lot of aftermarket clutches...
single plate clutches because of the very nature that its just one plate..need harder springs to hold the power thus its heavier. Twin plates and so on increase the friction area by having multiple plates which engage progressively thus the springs can be lighter. however, once they engage, they engage. there is hardly any biting point.
Have only used ORC before so I cant comment on other brands...but I love the ORC twin plate :)
  • 4 weeks later...
I've got a nismo coppermix twin comp edition in my 32 GTR and its superb! It did take a while to bed in as the competition one is a bit sticky but after some driving and a few launches its smooth as silk. It gives plenty of pedal travel and is easy to drive. I forget its even aftermarket... It's almost stock feeling.
Expect around $1800 for this one
Nismo C Spec coppermix. Been in my car for 7 years and never slipped. Drives awsome.
Coppermix twin spec C, love it, smooth takeoffs and very easy to use :D
I agree 100% with these two, drives like factory and holds well over 400 in stroker engines
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
