Ok im not near my car so I cant check.. and I want to buy. What is everyone running and what pipe dia am I looking at?
Does it get cold enough in sydney to require a thermostat?
Going to route to new cooler then through rad...
Edited by m35stagea
https://www.sau.com.au/forums/topic/423580-m35-transmission-cooler/
Repco - they sell re-branded PWR products. Get them to give you their catalogue flick through and pick the one you want.
3/8ths from memory. Thermostat is neither here nor there. Depends if you are driving 10 mins or 30 mins to work.
Running a Derale Series 7000 cooler on mine with one of those blue thermostats (I am also incorporating the OEM radiator inlet/outlets before both the thermostat and the cooler)
Comes with 3/8 hose but the barbs out of the transmission and OEM radiator are 8mm so recommend to get some 8mm clear plastic hose from Bunnings etc to use on the barb as a liner which will will out the inside of the 3/8 hose.
Why did you go radiator before the aftermarket cooler? I would of thought it is better to take some work off the radiators in these things?
Take work off the radiator? Man, I can only get over 80 degrees coolant temp if I sit on the side of the road idling for 5+ minutes.
What will happen with the external cooler before the radiator is that you will possibly be warming up the trans fluid on its way back to transmission.
Most efficient way of cooling is to have the ext cooler on the return line back to the transmission. If you are concerned about it getting too cold, just use a thermostat.
I was under the impression vq's had issues with cooling?
Just ordered 20L of matic j for 176 $ + gst so ill do cooler with shift kit... I noticed yesterday it was fairly warm and car seemed to feel it. I also noticed the clutch fan to be alot louder..
what side is the transmission inlet and outlet ?
They do run quite warm... without the cooling mod from Scott.
The line that enters the passenger side of the radiator is the trans outlet.
The problem with our auto is that it needs to be up to operating temp before it works right. If you go removing the line from the radiator or cooling the fluid to a more sensible temperature, it will drive like crap, or worse never drop in to 5th.
The way I got around it was to cut the two temp signal wires at the TCU and drop varisters over them. This tells the gearbox it is already at operating temp, allowing me to cool the fluid as much as I like and the bonus is it doesn't go into overheat limp mode on the track anymore.
  • Like 1
I love those kinds of mods - big win for little outlay. Not necessary for me but I like it anyway :yes:
Edited by Commsman
  • 3 years later...
Does someone still have an active link for those thermostats? Or possibly the suitable operating temperature for them? I see there are a few options out there including single inline type or supply and return type thermos, could anyone recommend what to go for as my set up will be stand alone cooler seperate from the radiator, hoping to fit it in somewhere behind the grille but always open to more advice, many thanks
http://www.amazon.com/dp/B008BTJFJ4/ref=pd_lpo_sbs_dp_ss_1?pf_rd_p=1944687582&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B000HE8HAY&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=03CJAYFFKWJZ02F2ND8S
The trans thermostats we used? Those ones linked, but there are heaps of different designs, most of which take up a lot more room.
Loading up the radiator by fitting coolers in front of it will not only make the radiator ineffective but overheat your aircon condensor too. Shame there are no side ducts. :/
  • Like 1
Need the Nismo front bar; a bit of side ducting there...
  • Like 1
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
